help...is there anybody familiar with hydro to cable conversion kits
i just installed a hydro to cable kit into my eg so i could run a b17 tranny
i am having trouble with getting my clutch to engage properly
i was wondering if there was anybody else that had these problems
and what was your solution
Did you properly bleed the clutch line?
The trick with the kit is to remove the cylinder slave all together using the rubber portion of the clutch line to position the cylinder slave at a horizontal position so the bleeder screw is facing upwards. Bleed the clutch line then and reinstall
well i bled the clutch the way the hasport rep reccomended
he told me to just have someone pump and hold like normal but instead of using the bleeder screw
take and loosten the hard line attached to the clutch master cylinder in order to let the fluid flow
i will definately try it your way tomorrow
also how far did you adjust the pushrod out (the pushrod attached to the release fork)
i have mine adjusted almost all the way out with about 1/4 inch of threads left in the aluminum pivot
Black R
13
Nov 15, 2004 08:14 AM
