Dizzy help for A6 mini me, using Z6 head. SEARCHED
Old Feb 5, 2004 | 04:56 PM
JSPECHB's Avatar
Default Dizzy help for A6 mini me, using Z6 head. SEARCHED
I started my mini me setup today and I'm having trouble with the dizzy. How do I get it to line up if theres a way? I searched and got nothing. If you can supply pictures that would be great!
Any other help would be nice. I know I need to remove the oil plug, and get a 92-95 EX timing belt. Can I use the Y8 head gasket? Will the coolant flow through the head correctly?
Old Feb 5, 2004 | 04:57 PM
89civicdx's Avatar
Default Re: Dizzy help for A6 mini me, using Z6 head. SEARCHED (JSPECHB)
You have to slot the holes alot to get it to line up and get enough advance
yup you can you use the y8
Old Feb 5, 2004 | 05:03 PM
JSPECHB's Avatar
Default Re: Dizzy help for A6 mini me, using Z6 head. SEARCHED (89civicdx)
Could I just use the Z6 or Y8 dizzy? What wiring would be involved in that? I'm using a MSD RPM activated switch for vtec engagement.
Modified by JSPECHB at 7:15 AM 2/6/2004
Old Feb 5, 2004 | 05:12 PM
89civicdx's Avatar
A6 works fine I can try to get pics for you tommorow....but you have to cut slots.
Old Feb 5, 2004 | 05:19 PM
phatrick2332's Avatar
make the top notch a little wider(not longer) and then just use big washers for the other 2 bolts..cuz the top is the only one that screws in.
Old Feb 5, 2004 | 05:23 PM
JSPECHB's Avatar
Default Re: (phatrick2332)
Can anyone get pics for me tonight? My car is at my buddy's house and I'm going there straight from school tomorrow. I could only get 2 legs to line up, the 3rd was way off. Like 1/2 inch.
Modified by JSPECHB at 7:07 AM 2/6/2004
Old Feb 5, 2004 | 05:29 PM
89civicdx's Avatar
Default Re: (JSPECHB)
its not good enough to just get it to bolt up you have to have some adj for advance and retard...slot the holes and like phatrick2332 said you big washers with the bolts.
Old Feb 6, 2004 | 03:07 AM
JSPECHB's Avatar
Can anyone get pics for me tonight? The car is at my buddy's house and I'm going there straight from school tomorrow. I could only get 2 legs to line up, the 3rd was way off. Like 1/2 inch.
Old Feb 6, 2004 | 03:18 AM
JSPECHB's Avatar
Anyone can help? This is all I need help on.
Ef4doorwagon
11
Mar 8, 2014 11:42 PM
jvillagran2000
27
Dec 3, 2008 05:06 PM
wmertz187
Feb 12, 2008 06:20 PM
keepinitsimple
Feb 17, 2005 11:32 AM
lazynok
13
Jul 27, 2004 11:10 AM
