Identify this Prop Valve
Old Feb 5, 2004 | 02:45 PM
FerioVtec94's Avatar
Default Identify this Prop Valve
which prop valve is this? i bought it used and is supposed to be a non-abs 40/40 valve, i'm just trying to make sure that i got the right part
any help will be appreciated
Old Feb 5, 2004 | 02:52 PM
splitime's Avatar
Default Re: Identify this Prop Valve (FerioVtec94)
It's not a 30/30 or a 40/40. At least like the integra 40/40 I recieved.
Modified by splitime at 7:07 PM 2/5/2004
Old Feb 5, 2004 | 03:03 PM
hasback*'s Avatar
F*CK THIEVES!
Default Re: Identify this Prop Valve (splitime)
hmm i wonder wth is dat also
Old Feb 5, 2004 | 03:36 PM
i found this article http://www.hazone.com/hdiscswap.htm where they swap a 99-00 si disc into a non-disc civic, if you scroll down the article the prop valve that they swap in appears to look like mine
could someone with an 99-00 SI look at theirs and see if it looks the same
Old Feb 5, 2004 | 04:01 PM
turbo_ef9's Avatar
looks like a 96- something
Old Feb 5, 2004 | 04:05 PM
Garrett's Avatar
Default Re: (FerioVtec94)
ABS car don'T have external Proportionning valve like this the PP is inside the ABS system. So civic si 99-00 don't have this piece
Old Feb 5, 2004 | 04:07 PM
2lua's Avatar
99 si none abs
Old Feb 5, 2004 | 04:08 PM
Garrett's Avatar
Default Re: (2lua)
In Canada it had ABS, USDM car sucks I think
Old Feb 5, 2004 | 11:03 PM
anyone else?
Old Feb 5, 2004 | 11:22 PM
pdiggitydogg's Avatar
looks like an si non abs to me too
Old Feb 6, 2004 | 12:14 AM
Mr. Samurai's Avatar
Default Re: (pdiggitydogg)
99 si's did have ABS, its the 2000's that dont have ABS
Old Feb 6, 2004 | 01:26 AM
soundbomber's Avatar
Default Re: (L33T)
Yep that's identical to my 99 si prop valve
Old Feb 6, 2004 | 04:14 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">Yep that's identical to my 99 si prop valve</TD></TR></TABLE>
and it's also going to be identical to all other 96-00 civic prop valves. You need to find out from the guy you bought it from the exact car it came off of.
unless it's from an Si then it's going to have the internal valving set up for drums.
the numbers on the outside are meaningless, just manufacturer lot codes from the date it was made.
Old Feb 6, 2004 | 11:06 AM
ok great thanks for all the help guys
Old Feb 6, 2004 | 11:33 AM
elwood's Avatar
looks a lot like a non-abs ctr prop valve I sold
a while back.
Old Feb 6, 2004 | 12:17 PM
kommon_sense's Avatar
Default Re: (elwood)
96-00 prop valves look the same. no markings to tell them apart.
phoxking
Apr 23, 2012 03:08 AM
Fo-Do Fanatic
Aug 18, 2010 10:15 PM
ahcapone
May 20, 2009 08:22 AM
silverxcivic
Jan 4, 2006 07:51 PM
fishnfst
Jun 27, 2003 09:46 PM
