Identify this Prop Valve
which prop valve is this? i bought it used and is supposed to be a non-abs 40/40 valve, i'm just trying to make sure that i got the right part
any help will be appreciated
Re: Identify this Prop Valve (FerioVtec94)
It's not a 30/30 or a 40/40. At least like the integra 40/40 I recieved.
Modified by splitime at 7:07 PM 2/5/2004
i found this article http://www.hazone.com/hdiscswap.htm where they swap a 99-00 si disc into a non-disc civic, if you scroll down the article the prop valve that they swap in appears to look like mine
could someone with an 99-00 SI look at theirs and see if it looks the same
at the jetties fishin'
Re: (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber »</TD></TR><TR><TD CLASS="quote">Yep that's identical to my 99 si prop valve</TD></TR></TABLE>
and it's also going to be identical to all other 96-00 civic prop valves. You need to find out from the guy you bought it from the exact car it came off of.
unless it's from an Si then it's going to have the internal valving set up for drums.
the numbers on the outside are meaningless, just manufacturer lot codes from the date it was made.
