question about OBD-1 conversion
Old Feb 5, 2004 | 11:44 AM
temp's Avatar
Default question about OBD-1 conversion
when this conversion is done, and you want to keep a cable speed sensor, how can one prevent the trouble code?
Old Feb 5, 2004 | 12:48 PM
tgreaves's Avatar
Default Re: question about OBD-1 conversion (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">when this conversion is done, and you want to keep a cable speed sensor, how can one prevent the trouble code?</TD></TR></TABLE>
You shouldnt throw a code.. The speedo cable goes up to the cluster and thats where the vss is.. The obd0 vss sends to the ecu so it will also do it with a obd1 converted harness also..
Old Feb 6, 2004 | 06:35 AM
temp's Avatar
Default Re: question about OBD-1 conversion (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
You shouldnt throw a code.. The speedo cable goes up to the cluster and thats where the vss is.. The obd0 vss sends to the ecu so it will also do it with a obd1 converted harness also..</TD></TR></TABLE>
could you elaborate? the OBD-1 VSS is in the tranny and it is electronically controlled, if you dont have that one in the tranny what is to stop it from throwing a code?
Old Feb 6, 2004 | 06:41 AM
tgreaves's Avatar
could you elaborate? the OBD-1 VSS is in the tranny and it is electronically controlled, if you dont have that one in the tranny what is to stop it from throwing a code?</TD></TR></TABLE>
Well your in the EF civic/crx forum.. Im assuming you have a 88-91 civic/crx that is obd0 converted to obd1 is that correct.. If it is then the vss is still at the gauge cluster..
Old Feb 6, 2004 | 07:17 AM
Davep's Avatar
You don't have to change the VSS to do the OBD 1 conversion, you use your original VSS and wiring. Everything will work fine.
Old Feb 6, 2004 | 07:20 AM
tgreaves's Avatar
Default Re: question about OBD-1 conversion (Davep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davep &raquo;</TD></TR><TR><TD CLASS="quote">You don't have to change the VSS to do the OBD 1 conversion, you use your original VSS and wiring. Everything will work fine.</TD></TR></TABLE>
Old Feb 6, 2004 | 09:57 AM
temp's Avatar
hmmmmmmmmmmm ok
Old Feb 6, 2004 | 10:03 AM
tgreaves's Avatar
Default Re: (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">hmmmmmmmmmmm ok</TD></TR></TABLE>
mmmmmmmm Yeah...
Old Feb 6, 2004 | 11:12 AM
90civichbsi's Avatar
Default Re: (temp)
i see where your confused, on an obd0 car w/ a cable speedo the speedometer cable runs to the cluster... then there is a signal wire that runs from the cluster to the ecu so that the ecu gets the signal.
Old Feb 6, 2004 | 11:26 AM
tgreaves's Avatar
Default Re: (90civichbsi)
Yup.. Actually the speedo even in an obd0 car is electronic.. Its just that the vss is mounted to the cluster.. So the cable goes to the vss and then output of the vss goes to the tach and to the ecu..
Modified by tgreaves at 3:39 PM 2/17/2004
rorik
May 9, 2011 01:10 AM
timdareez
10
Sep 10, 2009 05:39 PM
DJ 2501
Aug 13, 2008 12:34 PM
MikeySpec
Aug 12, 2004 01:46 PM
iNetForce
May 30, 2004 07:38 PM
