Apex'i Power FC and MSD DIS-2 / DIS-4?
Old Feb 5, 2004 | 11:41 AM
Andre's Avatar
Default Apex'i Power FC and MSD DIS-2 / DIS-4?
Can i use the Power FC together with the MSD DIS-2 or DIS-4 ignition?
Old Feb 5, 2004 | 01:46 PM
Boostin'RPS13's Avatar
Default Re: Apex'i Power FC and MSD DIS-2 / DIS-4? (Andre)
yes, my buddy is using DIS-2 w/Power FC on his SR.
Old Feb 6, 2004 | 11:53 AM
Andre's Avatar
Default Re: Apex'i Power FC and MSD DIS-2 / DIS-4? (Boostin'RPS13)
Anyone with a Honda?
Old Feb 25, 2004 | 04:54 AM
Andre's Avatar
Can i use a Distributorless Ignition System / Individual Coils with the Power FC?????
Old Feb 25, 2004 | 10:44 AM
onefstek's Avatar
It will work just fine. It just gets the timing from the ecu just like the oem ecu. I had it on mine for a while but I had no room in my eng. comp. so I took it off. But unless your buddy is making more than 250whp and has more than 11.5:1 cr, then he does not need it. 98ctr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andre &raquo;</TD></TR><TR><TD CLASS="quote">Can i use a Distributorless Ignition System / Individual Coils with the Power FC?????
Old Mar 14, 2004 | 06:35 AM
Andre's Avatar
Default Re: Apex'i Power FC and MSD DIS-2 / DIS-4? (98ctr)
ttt
Does anyone have a Power FC with coil packs or individual coils in a Honda?
I know the Nissan Power FC has two outputs to trigger the coils, but how about the Honda version?
Old Mar 17, 2004 | 06:59 AM
onefstek's Avatar
I belive that Honda has only one output therefore I don't think that you can run individual coils on a Honda. 98ctr
PS: here is a post that I found on the FcDatalogit forum that I belong to.
Subject: FC Edit for distributorless cars?
I think the Power FC for Nissan supports multiple coils, so are there
any settings for the ignition outputs?
I've read that the Power FC has 6 ignitions outputs. How can i
activate the other outputs and set them to work with a
distributorless ignition?
Or does the Honda version has only 1 output and the Nissan 6?
Old Mar 17, 2004 | 07:05 AM
Andre's Avatar
Thanks, i've posted that question
I'm currently thinking about to demultiplex the ignition signal with a simple microcontroller.
https://honda-tech.com/zerothread?id=801532
BunnyLuv70
Honda Civic (2006 - 2015)
Jan 1, 2014 11:09 AM
Takashi1978
Nov 5, 2004 06:30 AM
