Best price on air horns?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Was it common consenses that the Hella horns were really good? </TD></TR></TABLE>
I loved them in my VW.
Try http://www.rapidparts.com they specialize in VW and Audi's but they are good guys and sell alot of universal race fluids and parts etc.
I believe so. And they're only a few dollars more than the JC Whitney horns.
Double or triple?
Double or triple?
do you guys wire to replace the stock system or a seperate switch for when loud chit is necessary (one would argue that if you had to use the horn, it's probably nice when people actually hear it..)
replaced stock system:
here's a short clip of my sweet *** horns
http://cs.widener.edu/~epanek/Air%20horns.avi
(right click / save as)
-Make sure you wire up a clean power source from the battery to the air horn relay - they work MUCH better that way...
so if I had factory alarm that uses the horn, it should work fine correct? also, as this is an air-horn, is there a delay from pressing the horn to getting the loudnesses?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R »</TD></TR><TR><TD CLASS="quote">not if you wire it up correctly (using the relay)</TD></TR></TABLE>
Is the air horn relay juicier than the OE relay? I plan on running both horns - factory horn button wired to air horns, separate switch for stock horns for polite honks.
not really sure, but I ran a clean power wire from the battery to the air horn relay, and I haven't had any problems since... F the stoopid stock horn!
Actually the air horns have saved my *** more than once on I-95 (goddamned pickup trucks and tractor trailers...).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_97_ITR »</TD></TR><TR><TD CLASS="quote">Give these guys a peep...
http://www.rallylights.com/hella/horns.asp</TD></TR></TABLE>
Rick Solis
Jun 29, 2004 04:56 PM
Drinker
shi - who likes blasting st00pit pEEps0rz
