Fiberglass Never Smooth?
Old Feb 5, 2004 | 07:03 AM
Full Race A6's Avatar
Default Fiberglass Never Smooth?
Well ive decided to fiberglass everything that at first I thought I was going to bondo. ie door holes, rear quarter rust and Im also making an amp rack and a kick panels enclosure.
My question is when I read all these DIY's at the end they all use bondo anyways to fill in holes.
Is there no way to make fiberglass smooth without any holes? Because this will save me a lot of time and money if I know I cant get it smooth on the outside of my car.
Thanks
Old Feb 5, 2004 | 07:33 AM
rcurley55's Avatar
New User
Default Re: Fiberglass Never Smooth? (PIMPIN)
you will never get fiberglass perfectly smooth without some sanding effort unless you are pulling gel coated parts from a mold....
there's always finishing work to be done...
Old Feb 5, 2004 | 08:37 AM
eHoward's Avatar
Default Re: Fiberglass Never Smooth? (rcurley55)
True.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">you will never get fiberglass perfectly smooth without some sanding effort unless you are pulling gel coated parts from a mold....
there's always finishing work to be done...</TD></TR></TABLE>
A small tip would be to use glazing putty for the small holes instead of bondo.
Old Feb 5, 2004 | 09:56 AM
Default Re: Fiberglass Never Smooth? (eHoward)
No I no I cant get it smooth without sanding, but can I get it perfectly nice and smooth by using 60 grit, then 200 and then 600 grit. Would it be smooth with no pockets?
Old Feb 5, 2004 | 03:27 PM
Old Feb 5, 2004 | 03:35 PM
rcurley55's Avatar
New User
Typically, even a skim coat of bondo (or other plastic body filler) is step one. Then you can use either a putty (I like cake icing) to fill your pin holes or you can spray on some poly primer and sand away!
Old Feb 5, 2004 | 03:52 PM
cake icing??
Old Feb 5, 2004 | 04:00 PM
eHoward's Avatar
I use 3m red glazing putty. I think he's pulling your leg with the cake icing.
If you sand enough it will get smooth. It's easier to use a little bit of putty though and then sand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPIN &raquo;</TD></TR><TR><TD CLASS="quote">cake icing??</TD></TR></TABLE>
Old Feb 5, 2004 | 04:37 PM
rcurley55's Avatar
New User
Pulling your leg...naaaahhhh....
http://www.handsontools.com/st...=9170
Old Feb 5, 2004 | 07:15 PM
brads94accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">Pulling your leg...naaaahhhh....
http://www.handsontools.com/st...=9170</TD></TR></TABLE>
OMG i just checked the address on that site, that place is like two seconds away from my house, literally not even one mile away. now i know where to get some tools!
Old Feb 5, 2004 | 09:44 PM
philly-O's Avatar
Default Re: Fiberglass Never Smooth? (brads94accord)
there are tricks used to cut down sanding time, but there will always be sanding to be done.
Old Feb 6, 2004 | 02:54 PM
Default Re: Fiberglass Never Smooth? (peichie)
I dont give a **** about sanding and how long it takes me to sand. I just want to have to not use bondo and was wonderring if firberglass could be made with no holes on its own
Old Feb 6, 2004 | 03:41 PM
philly-O's Avatar
i dont understand why so many people have such issues with bondo. if used properly, it is a great tool for smoothing things. i dont think you can get fiberglass smooth enough to get pinholes out, just use glazing/spot putty to fill the holes.
Old Feb 6, 2004 | 08:18 PM
When I tried to shave my moulding with bondo I first attached a mesh sheet across the hole so I wouldnt have to use as much bondo. But There was always big hols and I could never get it smooth, would always be wavy.
Was my first attempt but it turned me off for sure
Old Feb 6, 2004 | 08:25 PM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPIN &raquo;</TD></TR><TR><TD CLASS="quote">When I tried to shave my moulding with bondo I first attached a mesh sheet across the hole so I wouldnt have to use as much bondo. But There was always big hols and I could never get it smooth, would always be wavy.
Was my first attempt but it turned me off for sure</TD></TR></TABLE>
I wouldn't shave mouldings with bondo - but that's just me personally...
you won't get anything right the first time when it comes to body work...gotta practice.
Seeing that people have been using bondo for years, it's an accepted step....gotta learn to work with it. If it's coming out really wavy, it may be your sanding procedure too...
I'm not a body man though, so I really can't help you too much past that...
Old Feb 8, 2004 | 05:56 PM
eHoward's Avatar
Try using a higher quality applicator. The bondo brand ones are kind of stiff and harder to use. I picked up some soft yellow ones from a local paint shop.
Also try using less hardener so that you have more work time to get it right.
Body work is tough and time consuming. Don't give up!
Old Feb 9, 2004 | 07:17 AM
Just picked up some glazing and spot putty, like 3 little tubes
Jlamar757
Jul 6, 2009 09:12 AM
nicokpe
Paint and Body
Sep 28, 2007 07:39 PM
chitownrida
Welding / Fabrication
Jul 10, 2006 10:27 PM
turbotime
10
Oct 13, 2004 03:39 AM
is3oo
Jul 16, 2003 10:37 PM
