Loss of Charge in battery?
Old Feb 4, 2004 | 11:11 PM
92CiviCJdMMX's Avatar
Default Loss of Charge in battery?
My hatch can not hold a charge, I have to jump it. I think its my altenator however, when I charge my battery up and let the the car sit for a day or two its completelt dead.
I just need reassurance that my altenator is the one not functioning right, or if it could possibly be something else.
Thanks Dave
Old Feb 5, 2004 | 12:12 AM
junkyardRx's Avatar
Default Re: Loss of Charge in battery? (92CiviCJdMMX)
most likely the alternator. try this:
start the car and let it idle, pop the hood and disconnect the battery ground cable. if it dies out, replace your alternator. if it doesn't might be a bad battery.
Old Feb 5, 2004 | 12:27 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
you might have a drain in the system somewhere.
it is too late for me to dig through my Helms, i will give you directions on charging system check tomorrow.
Stan
Old Feb 5, 2004 | 12:57 AM
ijjz's Avatar
Default Re: Loss of Charge in battery? (Stan D)
Mine starting doing this when I stopped driving it for awhile.. 3+ months. To avoid stuff like this just start it about every day if its going to sit still.
Old Feb 5, 2004 | 08:37 AM
90Ninja
Guest
Posts: n/a
Default Re: Loss of Charge in battery? (katsumoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katsumoto &raquo;</TD></TR><TR><TD CLASS="quote">most likely the alternator. try this:
start the car and let it idle, pop the hood and disconnect the battery ground cable. if it dies out, replace your alternator. if it doesn't might be a bad battery.</TD></TR></TABLE>
Don't try that! You could possibly send a spike through your electrical system and fry everything. That's an old chevy trick. I didn't get where you are from. If it's cold there, the cold weather can drain your battery if it sits.
Old Feb 15, 2004 | 12:28 PM
mskibbz-T's Avatar
Default Re: Loss of Charge in battery? (90Ninja)
Check the water level on your battery
Old Feb 15, 2004 | 12:30 PM
mskibbz-T's Avatar
Default Re: Loss of Charge in battery? (mskibbz-T)
Also, if you have AAA they'll come check your battery and alternator for free - and if you buy a new battery from them ~$85 / 5yr warranty then you don't get a point used up by the visit. Also you don't get any points if you have battery probs in the next 5 years and call em up... For a little more than a normal battery its cheap insurance
Scud
Feb 28, 2008 03:35 PM
young3bro
23
Dec 6, 2007 07:48 AM
tigueremalo
Jan 22, 2007 03:10 PM
calean
Nov 18, 2004 03:55 PM
ownedbyvtec
Aug 24, 2003 01:18 AM
