B18C1 or Civic Type R engine in a '97 EK?
I have a '97 civic EK i want to put a new engine in it, but i'm not sure wheather i should put a GSR B18 or a Civic Type R engine in it. the Type R engine is about $600 more but it also has 5 more hp (not much). plus being able to make my EK more jdm would be awsome. any recomendations. plus if i got the Type R engine i could turn it into an integera Type R engine.
yeah the type-r is about 5 more hps but look at the torque. the 1.8 gsr is going to respond better to mods. also if you want to go turbo or no2 then just bolt it on try that with correct me if im wrong but 11.0:1 compression B16B
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austinbionic316 »</TD></TR><TR><TD CLASS="quote">nope lol can't afford it</TD></TR></TABLE>
It doesn't cost much more than a B18C1 or B16B.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austinbionic316 »</TD></TR><TR><TD CLASS="quote">but that doesnt really answer my question tho, does the b16b handle boost well?</TD></TR></TABLE>
On what pistons??
On what pistons??
you might get a better response from the forced induction people, but i would think with the lower compression, the b18c will be the better motor for boosting...
also if you were planning on swapping the pistons out, i would probably still go with the 1.8 liter.
but if you were going to stay n/a, i would jump on the b16b.
Modified by BigBodySmith at 1:05 PM 5/6/2004
Modified by BigBodySmith at 1:06 PM 5/6/2004
I would definately buy the civic type-r motor. The b16b has the exact dimensions of the b18c's and ls's. it is a destroked 1.8. The block is bigger than a b16a. Therefor if u swap in the type-r crank and rods viola u have a b18c5 and its a 1.8 liter. You could even swap in an ls crank and rods and have a ls/vtec. ( would be cheaper than the type r stuff.
Of course u could do all this stuff with the b18c block too, but u wouldnt have the good parts like the type r head and b16b ecu.
skUnK2jdm
Jan 7, 2008 05:44 AM
fitted2k8
Sep 7, 2007 10:25 AM
