ys1 into crx
Old Feb 4, 2004 | 07:25 PM
michael O's Avatar
Default ys1 into crx
The jdm ys1 transmission I bought for my b16 has a power steering speed sensor. Can I just pull it out and plug in the crx speedometer cable or what do I have to do? Also does it matter what gear is on the end of it?
Old Feb 4, 2004 | 07:47 PM
Redline130's Avatar
Default Re: ys1 into crx (michaelOlson)
Unless you want to wire in the speed sensor, just switch it with a cable driven one.
Old Feb 4, 2004 | 08:07 PM
michael O's Avatar
Default Re: ys1 into crx (Redline130)
alright. Thx a lot.
Old Feb 4, 2004 | 10:37 PM
HandCommand's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">The jdm ys1 transmission I bought for my b16 has a power steering speed sensor. Can I just pull it out and plug in the crx speedometer cable or what do I have to do? Also does it matter what gear is on the end of it?</TD></TR></TABLE>
Umm? Are you sure you dont mean a JDM "Y1" cable tranny for your B16? Those are the ones with a ELECTRONIC speedo. Not the JDM "YS1".
If you have a JDM "YS1" it should already have a cable driven speedometer. You just need to add fluid and loop the speed sensitive steering hoses together.
Old Feb 5, 2004 | 05:58 AM
michael O's Avatar
Default Re: ys1 into crx (HandCommand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HandCommand &raquo;</TD></TR><TR><TD CLASS="quote">
If you have a JDM "YS1" it should already have a cable driven speedometer. You just need to add fluid and loop the speed sensitive steering hoses together.</TD></TR></TABLE>
yea I have a jdm ys1. So I just loop the hoses? I can't replace it with the crx speedometer cable?
Old Feb 5, 2004 | 06:05 AM
XJamesX's Avatar
you can just pop in the your old stock crx one but it isn't necasarry. I had the same speedo in my YS1 and I just pllugged up the wholes and it worked fine.
-james-
digitalernest
Feb 15, 2011 07:54 PM
Nick998
Mar 2, 2010 07:25 PM
EF-Devotion
10
Jul 27, 2009 06:35 PM
rdawg000
Feb 17, 2005 06:45 AM
Monty
Oct 5, 2002 09:46 AM
