What is difference about Suspension Tech. Sway Bar Set with/without factory front sway bar?
I am looking to purchase the sway bar set. I have 92 cx and believe to not have factory front sway bar. Whats the difference, I thought all 92-95 civics were the same. So just because it doesnt come with a factory sway bar you have to settle for the smaller diameter upgrade. Dont they bolt up in the same location or is there something I am missing. Please advise.....
st provides different hardware for those with and without factory swaybars. They mount a little different but work the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SolidGround_Accord »</TD></TR><TR><TD CLASS="quote">So can you use the kit with the larger front sway bar, if your car doesnt come with one from the factory</TD></TR></TABLE>
you need to get the appropriate kit for yuor car.your CX doesn't have factory swaybars,so you need to kit that kit.
Chris
Chris
i believe they dont want u using a large diameter rear without a front because u will get oversteer. when u already have a front sway bar, they just add a larger rear so u make your handling more neutral. someone correct me if im wrong.
