Help: Goodridge Lines Installed (Pics)
Ok, kind of a stupid question but I was wondering if anyone had pics of their goodridge lines installed (mainly on the front).
I don't need to know necessarily how to install them, I've already done that. I'm more concerned with where the slack should be and where to place that semi-clear rubber sleeve on the fronts.
The goodridge lines have those free floating brackets and this 1 inch rubber sleeve that hugs the line pretty snug. I just want to make sure I got the slack in the right spots so theres no tension on the lines as the suspension moves through its range of motion. Also should the rubber sleeve be slid against one of the brackets to keep the line from slipping back and forth through the bracket or should it be placed somewhere on the line to keep it from rubbing or wearing on something?
Munkyw3rkz.webs.com
i dont have pics of mine but make sure theres slack on both sides and use a zip tie around your folk (mine are on my coilovers) and thats that..mine looks clean wish i could show you
Its been a while but my goodridge lines were mounted to my kyb's. I dont remember exactly how much of a slack i had . But i had to adjust the free floating thing you were talking about.
Let me take some pics. I'll do it sometimes today
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22avid »</TD></TR><TR><TD CLASS="quote">So your coil overs don't have the place to bolt the line to? Is that why you had to zip em?</TD></TR></TABLE>
yes there is and they are bolted to then but the slack after that is what i zip tied
275Performance
Feb 11, 2004 01:06 PM
