P28 ECU
Old Feb 4, 2004 | 02:24 PM
Jasper_db1's Avatar
Default P28 ECU
I searched and found some information but am still unclear.
Will a P28 ECU run a B17A in stock form or does the ECU have to be chipped?
TIA
Old Feb 4, 2004 | 02:37 PM
PHiZ's Avatar
Default Re: P28 ECU (Jasper_db1)
the B17a1 originally ran off of a P61 ecu. The P28 ecu will run the motor, but not well. You're best bet is to have it remapped to fit your motor, and mods.
-PHiZ
Old Feb 4, 2004 | 03:17 PM
Katman's Avatar
Default Re: P28 ECU (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">the B17a1 originally ran off of a P61 ecu. The P28 ecu will run the motor, but not well. You're best bet is to have it remapped to fit your motor, and mods.
-PHiZ</TD></TR></TABLE>
yeah whut he said.
The P28 runs a bit lean for a b-series engine, reprogramming is highly suggested, but it will run your engine regardless.
Hit me up if you need your P28 reprogrammed
Old Feb 5, 2004 | 04:18 PM
Jasper_db1's Avatar
Default Re: P28 ECU (Katman)
Thanks, how does the reprogramming process work? I tell you my specs and you build the program based on that information?
trip-doh
Jun 27, 2011 03:59 PM
Jap_Spec_Imports
Oct 29, 2009 08:32 PM
Lasky
Nov 9, 2007 11:29 AM
havalilsi
Oct 4, 2004 11:57 AM
gookspeed
May 15, 2004 02:58 AM
