Useless engine bay materials?
Just wondering what i can rip out of my std crx engine may, i want too take out anything that doesent make the car move.Its gonna be my drag car.I noticed my friends and it has nothing in it.He said its mostly ac components.Do i need any special tools too remove this?
all your AC components, power steering if you have that, washer bottle and components, if you don't care about safety, rad support, bumper support, engine bottom cover
AC Lines, evaporator, condensor, dryer, compressor, and wiring~50-55lbs.
Battery and support~0lbs (since you still have to relocate it)
Washer fluid resivoir and lines~1lb
Half radiator~10lbs
EVAP system~2-3lbs
PCV system<1lb
Bumper support~15lbs (im just going to cut 10lbs off mine
CF hood~varies
-Dustin
[edit:you will need the upper firewall plug and lower firewall plug when you remove the A/C]
Half radiator~10lbs
EVAP system~2-3lbs
PCV system<1lb
)CF hood~varies
-Dustin
acura_el2000
Aug 25, 2011 06:45 PM
