What does ecu code 15 Ignition output signal mean
I just read the code from the ecu and it is returning code 15 Ignition output signal. Does this mean a problem with the distributor? or what really need your guys help I need to get my car running`!!!!!!!!!
i had that when the plugs on the ECM were loose and the car started to run really bad (tach jumping and car stalling), i clamped the plugs smaller so they fit on the ECM terminals better
everythig was fine after that. hope this helps
dhernandez_9117
Oct 13, 2009 06:29 AM
kuteboi
Jan 29, 2005 09:11 PM
