Shifter & Idle problem
Old Feb 4, 2004 | 11:44 AM
speedehatch's Avatar
Default Shifter & Idle problem
I have a d16y7 still with only 45000 miles and its giving me problems. My first problem is the idle. When i first start it, and its cold it will stay streight at 1500-2000 RPMs. When i start driving and it warms up it develops into a very erratic idle, The Tach. needle moves VERY fast, and irraticly between 500 and 700 RPMs. But it doesnt sit there, the Tach again shows it moving very irraticly. What is the problem? Ive been to shops and they check my idle control, and timing n it checks fine.
Also n i think it may be related. My shifter and **** vibrate like CRAZY. I mean a girl could get an orgasm it vibrates so much, again erraticly along side what the Tach. shows.
Old Feb 4, 2004 | 11:52 AM
Default Re: Shifter & Idle problem (speedehatch)
The engine is also very noisey. I cant need a valve adj. b/c i just had one like last summer. Noise seems to be coming from where the head and manifold connect. Around that area. Maybe that will change when i swap in the y8 manifold.
Old Feb 4, 2004 | 12:11 PM
Any ideas???
Old Feb 4, 2004 | 02:23 PM
Mr. JDM-GSR's Avatar
check the wires with the TPS sensor.
Old Feb 4, 2004 | 04:31 PM
Default Re: (Mr. JDM-GSR)
bump
Old Feb 4, 2004 | 07:10 PM
Default Re: (speedehatch)
Does anyone have anea ideas???
Old Feb 5, 2004 | 02:07 AM
tegmech's Avatar
check the voltage on the tps. it should read around .46 volts i believe.
Old Feb 5, 2004 | 08:31 AM
alex12321's Avatar
check your tps, make sure there are no leaks in the vacume. also does it ever go away? like when the engine warms up? Could be a problem w/ the temp sensor, play around w/ it
Nisif
Nov 26, 2011 07:22 PM
90AcuraIntegra04
Dec 11, 2005 05:26 PM
2000civicsi
10
Oct 26, 2005 04:05 PM
NJAman
Jan 17, 2005 10:19 PM
stRtypR25
Jan 12, 2003 03:09 PM
