what can it be?????
Old Feb 4, 2004 | 10:45 AM
Driftmechanix's Avatar
Default what can it be?????
i've just changed out both axles on my 97 lx, took it for a test drive and the car starts to pull to the right. i was wondering if anyone has the same problem, or if anyone know what might cause this. the suspension was changed about 3 months ago w/ an alignment just so you know.
Old Feb 4, 2004 | 11:34 AM
fw190bvi's Avatar
Default Re: what can it be????? (Driftmechanix)
needs another alignment.....if the work was done by a shop, take it back to them if teh alighment doenst help at all
Old Feb 4, 2004 | 05:19 PM
ERICH's Avatar
correct axles? bad wheel bearing? hanging up caliper? worn/bad halfshaft? low tire pressure?
Old Feb 5, 2004 | 10:14 AM
i noticed that the driver side wheel is easier to turn than the passenger wheel. is that normal?
Old Feb 5, 2004 | 03:33 PM
VTECsam's Avatar
Default Re: (Driftmechanix)
bad swar bar?
Old Feb 6, 2004 | 09:16 AM
jdmjason's Avatar
balance the tires? check the brakes?
Old Feb 6, 2004 | 09:30 AM
.bagged's Avatar
Default Re: what can it be????? (ERICH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ERICH &raquo;</TD></TR><TR><TD CLASS="quote">correct axles? bad wheel bearing? hanging up caliper? worn/bad halfshaft? low tire pressure? </TD></TR></TABLE>
What he said
Damn you...that is what i was saying in my head
Old Feb 6, 2004 | 12:33 PM
90Ninja
Guest
Posts: n/a
Default Re: what can it be????? (bagged93accord)
Check the calipers, or the passenger side caliper. Could be hung up on the rotor.
dem0nk1d
13
Nov 3, 2010 02:01 PM
VTECcnIT
Feb 21, 2006 06:46 PM
stealth_EK4
Suspension & Brakes
Aug 21, 2005 09:35 PM
Ricochet.
Nov 3, 2004 03:45 PM
