Anyone swaped DX tranny to Ex tranny?
I have a 94 civic DX and i have parts from a 93 civic EX i want to put the tranny from the ex in my dx but i dont know if i need to swap out anything else to make the tranny work right like.. axels, cv joints, struts, clutch **** like that , can anyone help me out who has done this project before?!
See that exacly what i thought it bolted right up, but then i went to a guy i know who owns a shop where my Ex is sittin that i will be using the parts off of, and he wasnt sure if the front hubs on and 93 ex are the same as a 94 dx. so i dont know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx »</TD></TR><TR><TD CLASS="quote">See that exacly what i thought it bolted right up, but then i went to a guy i know who owns a shop where my Ex is sittin that i will be using the parts off of, and he wasnt sure if the front hubs on and 93 ex are the same as a 94 dx. so i dont know</TD></TR></TABLE>
They're all the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon Spec EK »</TD></TR><TR><TD CLASS="quote">You will have no problems with it. Get on with your project!
ha i want to i just need to know if everything will be correct, i dont want to have it all apart and have to order parts just to get it on.
</TD></TR></TABLE>ha i want to i just need to know if everything will be correct, i dont want to have it all apart and have to order parts just to get it on.
yups....i can vouch that its direct bolt on. even better to prove it i have a 94 dx motor with a 99 ex tranny. besides swapping over the bracket on the tranny its the same. if you have a 92-95 ex tranny then you dont even need to swap brackets....if you have a 96-00 you'll need to. but besides that its totally bolt on.
On 92 to 95 manual trans civics you don't have to worry about different axles & hub/knuckle. Only on 88 to 91 did Hf & Standard civic/crx use different drivetrain parts from DX & Si.
i dont have a ex but i have an hx which is almost the same. i love it. it bolted right up and all the harnesses and wires fit perfectely. but unfortunately i have to take it out again to rebuild it.
but oh well. it was only 100bux
DeathByBoost
Aug 13, 2006 07:53 PM
flatblakd15vt
14
Mar 22, 2006 04:09 AM
Kyles ej1
14
Aug 17, 2004 04:08 PM
