strut bar question
Thats cause your car was not designed to have a factory strut bar like the Si and Type R. You have two little black caps right? I guess you would have to get the screw inserts or something for it to bolt up to your chassis.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">Thats cause your car was not designed to have a factory strut bar like the Si and Type R. You have two little black caps right? I guess you would have to get the screw inserts or something for it to bolt up to your chassis.</TD></TR></TABLE>
he dosnt have any of the holes. Havnt seen that on a hatch,
but on a coupe I have. Just line it up and drill through.
dont worrie about getting special mounting hardware, just regular
nuts and bolts will hold it on fine.
man, dont drll your car. look closer. i have a dx hatch and it certainly didnt come with a strut bar. probably the black rubber caps are cover the holes. they should be around the top of your strut. just take off the caps and gets some nuts and bolts and bolt that strut up.
apalmucci
22
Mar 23, 2011 01:36 AM
erasable180
Nov 24, 2005 06:17 PM
