Shaking under acceleration .. help!
Old Feb 3, 2004 | 08:06 PM
redlineintegra's Avatar
Default Shaking under acceleration .. help!
I have a 90 DA, and recently this problem began .. it's basically a really noticeable shaking under moderate-heavy acceleration, and I need to get this fixed, very annoying. I am thinking it might be my rear motor mount (never been replaced), but I haven't been able to get under the car and inspect it. I'm in the middle of building a motor (LS) so if it is the mount, I'll replace it when the new motor goes in. Any other ideas? I know it's not my axles .. Thanks.
Old Feb 3, 2004 | 08:32 PM
tinkerbell's Avatar
Default Re: Shaking under acceleration .. help! (redlineintegra)
i have a 90 DA with B20VTEC and it shakes a bit too...
i have watched it on the dyno and it seems to vibrate lengthwise across the engine bay, not from front to back...
it seemed like the timing belt side engine mount was too sloppy...
i was thinking of trying a newer b18c style mount...
but i dont really worry too much about it... just gotten used to it (has always been there)
Old Feb 3, 2004 | 11:14 PM
swiftstyles's Avatar
Default Re: Shaking under acceleration .. help! (tinkerbell)
I also have a 92 da with a b20z/vtec set up, with new Place racing motor mounts and it vibrates on acceleration between 3-4.5k rmp. I dont thinks its the mounts cuz it did that also when I had the old stock mounts in them. Something with the engine imbalance or something.(talking out of my *** ).
Old Feb 4, 2004 | 01:22 PM
tinkerbell's Avatar
nah - not talking out your *** - it only happens with B20's
i reckon it could be the crank balance or something...
i am not to worried, as you say - it goes away at higher RPM...
Old Feb 4, 2004 | 01:39 PM
leadfoot78's Avatar
Are your axles clicking? If they are than thats your problem 99.9% of the time. I had it, the outer boot would bind when moved by hand, made the axle click when turning and made the motor vibrate when I was accelerating.
Old Feb 4, 2004 | 04:03 PM
Default Re: Shaking under acceleration .. help! (leadfoot78)
I had both of my axles replaced brand new so it cant be that!
Old Feb 4, 2004 | 08:44 PM
leadfoot78's Avatar
Default Re: Shaking under acceleration .. help! (swiftstyles)
than it must be the mounts, id fix them cuz in extreme cases broken mounts can lead to broken axles.
Old Feb 5, 2004 | 04:26 PM
I'm pretty convinced it's my mounts (mainly the rear mount), just wanted to see if anyone had any unusual causes besides axles or clutch issues I could check for. Thanks guys!
airikkCRX
Jul 12, 2008 05:24 AM
thaipham806
Nov 24, 2006 03:30 PM
83Rabbit
Jun 16, 2005 08:01 AM
Rocks
11
Jul 23, 2004 11:19 AM
CircuitFG
Jun 24, 2003 06:50 PM
