get codes from ecu..
Old Feb 3, 2004 | 07:27 PM
crxsirvtec's Avatar
Default get codes from ecu..
hey..
i have a 91 crx.. and i swap it to obd-1.. i have an engine light, how do i get the code..
thanks
Old Feb 4, 2004 | 01:06 PM
crxsirvtec's Avatar
Default Re: get codes from ecu.. (crxsirvtec)
anything??
Old Feb 4, 2004 | 01:14 PM
Katman's Avatar
for a CRX, go to where the ecu is (passenger footwell area), take a look at the ecu. There's a small round window on the topside, you should see a red light blinking in that window. Take note of the blinks and this should help you figure out what code(s) your ecu is throwing.
Old Feb 4, 2004 | 01:25 PM
Kataku2K3's Avatar
Default Re: get codes from ecu.. (Katman)
Since your car is converted to OBDI, hopefully there is a wire coming out of the OBDI point D4 (this is the way I always wire it when doing nonOBD-OBDI conversions)... If there is then it's really simple... Just ground this wire to activate your CEL... If not then you can probably either install an OBDI pin (if you have one) or just jam a wire into the same point (D4) and run the other end to ground...
Old Feb 4, 2004 | 01:38 PM
crxsirvtec's Avatar
thanks -> Kataku2K3
Old Feb 4, 2004 | 03:24 PM
Katman's Avatar
doh! missed the part where mentioned he converted to OBD1. solly.
O RLY
10
Jul 2, 2007 07:28 AM
Stunna MIKE
13
Feb 6, 2006 10:43 AM
yellowjdmcrx
17
Nov 21, 2005 02:57 AM
HamiltonRex
Nov 14, 2004 03:46 PM
baonest1
Mar 18, 2003 09:48 AM
