my compression numbers... b18c1
Old Feb 3, 2004 | 03:28 PM
stockegsix's Avatar
Default my compression numbers... b18c1
from dizzy to cam gears, 210, 200, 210, 210. is this normal? the motor is 1995 b18c1 bone stock. i dont know the mileage of the motor, im guessing somewhere between 65k-80k.
Old Feb 3, 2004 | 03:29 PM
JDMb18civic's Avatar
Default Re: my compression numbers... b18c1 (stockegsix)
thas about normal...
Old Feb 3, 2004 | 03:30 PM
93civicEX's Avatar
looks real good
Old Feb 3, 2004 | 03:42 PM
GRAVEDIGGER's Avatar
Default Re: my compression numbers... b18c1 (93civicEX)
within spec.
Old Feb 3, 2004 | 04:12 PM
Matty.'s Avatar
almost perfect.
how many times did you turn it over?
Old Feb 3, 2004 | 04:18 PM
stockegsix's Avatar
Default Re: my compression numbers... b18c1 (gumtape_deathmatch)
i pulled the ecu fuse, steped on the clutch and turned it over seven times per cylinder.
Old Feb 3, 2004 | 04:23 PM
G U E C O's Avatar
damn thats good. i dont know if i did this right but i got 180 180 170 180 its a 99 freshly rebuild engine. bone stock i cranked it 7 times too.
Old Feb 3, 2004 | 04:36 PM
stockegsix's Avatar
Default Re: (stock93cx)
i think when i got to cylinder#3 i might not have tighten the tester all the way and not even sure if i did crank it seven times(i was worried about the battery going dead) what compression tester did you use?
Old Feb 4, 2004 | 01:38 AM
Vtec92Civic's Avatar
Default Re: (stockegsix)
look'n good on those #'s
Old Feb 6, 2004 | 11:48 AM
Boofster's Avatar
Default Re: (Vtec92Civic)
I got 180,180,180,182 on my 40k mile '96 GSR (stock everything). Craftsman gauge. Why is there such a big difference between the perfect 210 and the 180's? Seems those two are prevalent numbers on working engines.
Old Feb 6, 2004 | 10:18 PM
stockegsix's Avatar
Default Re: (Boofster)
i also got a craftsman compression tester, the motor was never modified in anyway.
nissa240
May 1, 2009 08:14 AM
DropSide
Apr 18, 2007 06:22 PM
AlphaQup
Jul 12, 2005 02:58 PM
57one
Aug 14, 2002 05:06 AM
GQ 05YellowEVO8
Jan 3, 2002 01:29 PM
