Cam timing on a shaved head
Old Feb 3, 2004 | 01:30 PM
Griffin@Camtech's Avatar
Default Cam timing on a shaved head
I know shaving a head retards camshaft timing but how much? My head has been milled 20 thousandsths how man degrees of advance do I need to bring me back to 0?
Thanks
Old Feb 3, 2004 | 02:11 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: Cam timing on a shaved head (EK2NR)
yeah i would like to know too
Old Feb 3, 2004 | 02:31 PM
Rocket's Avatar
Default Re: Cam timing on a shaved head (streetdreams02)
On a B-series the cams gears are 100mm in Dia. So the circumfrence of the cam gear is 314mm (100mmxPI). Divide 360 degree by 314 = 1.14 degree per mm.
So for every 1mm milled the cam gears will roll back (retard) 1.14 degrees at the cam or 2.3 degrees at the crank.
So you have a 0.020 milled meaning 0.50mm = about 1.14 degrees retarded, so advance your gears 1 degree to compensate for the 0.020" mill.
Hopes this helps you guys out.
Old Oct 1, 2005 | 10:12 PM
TrackSpeedRacing's Avatar
Default Re: Cam timing on a shaved head (Rocket)
Thanks for the info sir.
Old Oct 1, 2005 | 11:00 PM
scUba-stEve's Avatar
rocket has always been "THE MAN".
Old Oct 2, 2005 | 09:01 AM
non-vtecpower's Avatar
I need adjustable cam gears..But in the mean time with the stock cam gears is there anything i can do with my LS so it will run better.. The head is shaved 30 thousands
Old Oct 2, 2005 | 03:21 PM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">On a B-series the cams gears are 100mm in Dia. So the circumfrence of the cam gear is 314mm (100mmxPI). Divide 360 degree by 314 = 1.14 degree per mm.
Hopes this helps you guys out.</TD></TR></TABLE>
Nice math lesson there! I like to play around with formulas all the time, now I have a new one to add to the list.
Old Oct 6, 2005 | 05:21 PM
Power Rev Racing's Avatar
Default Re: Cam timing on a shaved head (hybrid_vtec)
Great post. Need this in my recent topics.
Old Oct 6, 2005 | 07:08 PM
Used2beAb16's Avatar
Default Re: (non-vtecpower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-vtecpower &raquo;</TD></TR><TR><TD CLASS="quote">I need adjustable cam gears..But in the mean time with the stock cam gears is there anything i can do with my LS so it will run better.. The head is shaved 30 thousands</TD></TR></TABLE>
Fat head gasket?
neofreak
25
Jan 1, 2007 12:33 PM
Bevin
Sep 19, 2006 11:01 PM
sik_sol
Apr 2, 2005 12:52 PM
nigel
Feb 9, 2004 11:20 AM
donnjuan2point2
Sep 30, 2003 10:02 AM
