AC Compressor not working
Old Feb 3, 2004 | 12:53 PM
shannon's Avatar
Default AC Compressor not working
My AC compressor is not working does anyone knows what the possible causes can be ?
Old Feb 3, 2004 | 02:21 PM
shannon's Avatar
Default Re: AC Compressor not working (shannon)
ttt
Old Feb 3, 2004 | 02:32 PM
shannon's Avatar
ttt
Old Feb 3, 2004 | 04:02 PM
Mike P.'s Avatar
25 Year Member
Could you perhaps give us any symptoms? Does the compressor clutch itself on when you turn it on with the HVAC controls? Does it kick on and off repetitively? Does it not "click" on at all?
Old Feb 3, 2004 | 05:36 PM
shannon's Avatar
Default Re: AC Compressor not working (Mike P.)
No the clutch doesn't kick in at all
Old Feb 3, 2004 | 06:40 PM
Mohudsolo's Avatar
If the system pressure drops below a specific amount, the system will not activate to prevent compressor damage. There is a pressure sensor near the driver's side headlight that controls it. If you jump across it and the compressor starts up, the system is low. You can try a recharge kit, but it leaked out somewhere so you may want to have that checked out. If the leak is slow enough, just recharge it when it stops working, your choice.
Old Feb 3, 2004 | 06:55 PM
shannon's Avatar
Default Re: AC Compressor not working (Mohudsolo)
A guy that fixes AC told me that it might be some kind of wires (winding) that are located in the front of the compressor .can this be true?
Old Feb 3, 2004 | 08:17 PM
Mohudsolo's Avatar
The clutch in the system works electrically, that is probably what he meant. To see if it's just the system pressure being too low, take the connector off the sensor and connect a jumper wire between the terminals of the connector. If it's the system pressure, the compressor will now engage. Don't run it for very long since there is very little refrigerant in the system. If it engages, charge the system back up. If it does not engage, there are a bunch more tests that have to be tried.
Old Feb 5, 2004 | 11:51 AM
shannon's Avatar
I did jump the connecter but the compressor did not engage . Some guy told me it's the compressor coil . Can this be true ? And how do I fix it or does it need to be replaced? Thanks.
Old Feb 6, 2004 | 10:03 AM
shannon's Avatar
I finnaly found the problem It's a burned relay of the compressor.Thanks guys
Zebra
Honda Civic (2006 - 2015)
10
Jul 5, 2018 04:32 PM
SIR 1.6
Aug 1, 2012 05:23 AM
75aces
Mar 4, 2011 03:10 PM
jamesjarvis85
Sep 12, 2007 01:04 PM
jabroni95gsr
Dec 18, 2002 07:00 AM
