1.5 sohc and a 1.6 sohc. intake manifolds
Old Feb 3, 2004 | 12:01 PM
KuunLB's Avatar
Default 1.5 sohc and a 1.6 sohc. intake manifolds
Will the multi port fuel injected intake manifold from the 1.6l engine fit onto the 1.5 without major modifications? if so does it require a ECM swap?
i know the MPFI has better fuel efficiency and im wanting to get more miles per tank outta my car.
i've got an 89 hatch 5spd with a 1.5l sohc no mods
Old Feb 3, 2004 | 02:05 PM
95civ2121's Avatar
Default Re: 1.5 sohc and a 1.6 sohc. intake manifolds (KuunLB)
if you have no internal mods it will be pointless save yourself time and money
the motor is a vacum it only suck so much air putting a larger bore throtle body
will help throtle response but too much work for little profit get a good air filter
for better gas mileage
Old Feb 3, 2004 | 02:59 PM
TeamNextGenChris's Avatar
the manifold will fit,but it will require wiring your car for multi-point injection,along with the proper ECU.http://tech.hybridgarage.com/t...g.htm this will give you an idea of the wiring.
if your main concern is fuel mileage,i'd leave it alone.i don't think you'll gain any mileage with the multi-point,and if you do,it won't be enough to justify the work and cost.
chris
jmucivicsi
Sep 9, 2007 08:16 PM
user 6297290
47
May 26, 2005 11:21 AM
wpgcivic
Dec 17, 2004 06:25 PM
ExospeedAMcrx
36
Jul 26, 2003 08:43 AM
X-Mazda 3 Racer
Apr 28, 2003 04:14 AM
