b18 GSR block w/ b16 head - What Injectors to run?
Old Feb 3, 2004 | 11:26 AM
Zew's Avatar
Zew
Default b18 GSR block w/ b16 head - What Injectors to run?
I have a OBD1 b18 GSR block that is bored .040 over (P73-A0 pistons 10:6 compression) with a ported b16 head that has a ported stock intake on it with a 74MM throttle body. I have a 255lph fuel pump w/ AEM filter, rail, and regulator. Not sure on what horsepower it will turn out just yet, cuz it's not done. I was wondering what type of injectors should i run and what size they should be. I know of a set of ND DSM Honda 275cc's up for sale... But will those work? They seem to have a really long nose on them, compared to stock ones.
Can anyone help?
-Paul
Modified by Zew at 8:48 PM 2/3/2004
Old Feb 3, 2004 | 11:32 AM
DVS_EF's Avatar
Default Re: b18 GSR block w/ b16 head - What Injectors to run? (Zew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zew &raquo;</TD></TR><TR><TD CLASS="quote">I have a OBD1 b18 GSR block that is bored .040 over with a ported b16 head that has a ported stock intake on it with a 74MM throttle body. I have a 255lph fuel pump w/ AEM filter, rail, and regulator. Not sure on what horsepower it will turn out just yet, cuz it's not done. I was wondering what type of injectors should i run and what size they should be. I know of a set of ND DSM Honda 275cc's up for sale... But will those work? They seem to have a really long nose on them, compared to stock ones.
Can anyone help?
-Paul</TD></TR></TABLE>
dam, 74mm TB and a 255lph fuel pump dunno bout' that one.. your stock gsR (240cc) should be good for now, BTW you didn't say what compression you were running...
Old Feb 3, 2004 | 11:49 AM
Zew's Avatar
Zew
Default Re: b18 GSR block w/ b16 head - What Injectors to run? (dvsef)
P73-A0 pistons running 10:6 compression, sorry.
Old Feb 3, 2004 | 12:09 PM
DVS_EF's Avatar
your stock (gsR) 240cc's will do then.. until you get higher compression pistons..
Old Feb 3, 2004 | 12:17 PM
Zew's Avatar
Zew
Don't plan on getting different pistons. With the b16a head, doesn't that bring the compression up? I think it's higher than 10:6, but i'm not sure.
It's a http://www.DH-Racing.com engine.
As for your comment about the TB and fuel pump... Overkill? 74MM TB is what they sent me w/ the intake. The fuel pump i got brand new for 40 bux.. i couldn't pass it up.
Old Feb 3, 2004 | 12:18 PM
LudeToAHatch's Avatar
yup... stock injectors are fine. I'm running them and my cr is 11:5:1
Old Feb 3, 2004 | 01:20 PM
TECH43 RACING INC.'s Avatar
Default Re: b18 GSR block w/ b16 head - What Injectors to run? (LudeToAHatch)
stock is fine..compression is LOWER with a b16a head compared to a gsr.
Old Feb 3, 2004 | 02:16 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zew &raquo;</TD></TR><TR><TD CLASS="quote">I have a OBD1 b18 GSR block that is bored .040 over (P73-A0 pistons 10:6 compression)
Modified by Zew at 8:48 PM 2/3/2004</TD></TR></TABLE>
i thought that u could only get stock pistons .25 over
Old Feb 3, 2004 | 02:33 PM
Zew's Avatar
Zew
Default Re: b18 GSR block w/ b16 head - What Injectors to run? (streetdreams02)
its stamped right on the top .040
Old Feb 3, 2004 | 03:49 PM
the .020 and .040 itr pistons are NOT honda...they are aftermarket and the oversized bore number is standard, not metric like the honda (.25 is 1/4 mm)
Old Feb 4, 2004 | 02:10 PM
Zew's Avatar
Zew
Default Re: b18 GSR block w/ b16 head - What Injectors to run? (TECH43 RACING INC.)
I hate being a trial user... couldn't post again cuz i was at 5 posts for a 24 hr period.
In talking to the guys at DH-Racing.com, they are planning on milling the head, and they also say that the P73 pistons are not stock replacements and will have higher compression. They say total compression on the engine should be 11.5:1. Knowing this... what size should the injectors be?
Just wanted to say thanks for the info.
-Paul
Old Feb 4, 2004 | 04:02 PM
skunked's Avatar
stock.stock.stock.stock. You could run bigeer if you wanted but they are not needed without some bigger cams or dispalcement.
Old Feb 4, 2004 | 05:49 PM
HondaRacer32's Avatar
how many liters is a GSR b18c motor?
Old Feb 4, 2004 | 08:35 PM
Zew's Avatar
Zew
Default Re: b18 GSR block w/ b16 head - What Injectors to run? (HondaRacer32)
stock gsr is 1.8L
Old Apr 21, 2004 | 10:09 AM
DTSbmxKID's Avatar
correct me if im wrong but putting a b16a head on a b18c1 block lowers the compression. the guy who is telling you that your compression will be higher than what the pistons are rated is a moron. maybe you should take your motor somewhere else where they know what they are talking about. By the way your stock gsr or b16 injectors should be fine.
Old Apr 21, 2004 | 12:27 PM
X2BOARD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. &raquo;</TD></TR><TR><TD CLASS="quote">the .020 and .040 itr pistons are NOT honda...they are aftermarket and the oversized bore number is standard, not metric like the honda (.25 is 1/4 mm)</TD></TR></TABLE>
They who makes what's in his block ??
I know honda makes 0.25 and 0.50 over... never seen a 0.40 over.
Old Apr 21, 2004 | 12:38 PM
turboxsi's Avatar
use http://www.c-speedracing.com and use the compression calculator its a good approximate.
Old Apr 21, 2004 | 12:55 PM
:thumbsdown:
Guest
Posts: n/a
Default Re: b18 GSR block w/ b16 head - What Injectors to run? (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">
I know honda makes 0.25 and 0.50 over... never seen a 0.40 over.</TD></TR></TABLE>
Thats in METRIC.
The ones he has is in INCHES.. so convert .40 inches to metric.. It comes out to 1mm over stock.
He has 82mm pistons.
Oversize = more compression.
In a gsr block w/ gsr crank and b16 head.. he should be around ~11.2CR, with 1842cc = 1.84 liters.
If he were to run a LS Crank/rods he'll have ~11.5CR, w/ 1880cc = 1.88 liters.. aka people call it 1.9L
Site in my sig sells those pistons.
Old Apr 21, 2004 | 02:08 PM
Jockdeeznutz's Avatar
Default Re: b18 GSR block w/ b16 head - What Injectors to run? (:thumbsdown:)
I kinda have the same setup B18C block with a b16 head. Still waiting for my CTR pistons. My Cr is prolly gonna be 11:1 12:1?
Old Apr 21, 2004 | 03:56 PM
iluvkarekare's Avatar
Default Re: b18 GSR block w/ b16 head - What Injectors to run? (Jockdeeznutz)
Stock GsR block w/ a Stock B16 head u should yeild a 10:4.1 CR or lower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jockdeeznutz &raquo;</TD></TR><TR><TD CLASS="quote">I kinda have the same setup B18C block with a b16 head. Still waiting for my CTR pistons. My Cr is prolly gonna be 11:1 12:1?</TD></TR></TABLE>
Should be less than 12:1, around 11:5 or 11:7. Correct me if im wrong guys
jdmjeff
Nov 14, 2005 01:16 PM
JspecCivic94
Oct 25, 2005 06:26 AM
DC2SIR-G
Oct 18, 2005 02:05 PM
3gsi
Aug 6, 2005 05:09 PM
aser1z
Apr 25, 2005 01:17 PM
