93 ex electrical problem
Old Feb 3, 2004 | 07:43 AM
onewisepunk's Avatar
Default 93 ex electrical problem
When I use my turn signals, my tach and speedo needle go nuts! Then if use my
brakes, and turn signals, the radio cuts out and the tach and speedo go out!
What do you guys think?
Old Feb 3, 2004 | 02:41 PM
Riceburner247's Avatar
Default Re: 93 ex electrical problem (onewisepunk)
never heard of it before, but it just sounds like you have a short somewhere in your electrical system. Have you or anybody been messing around under the dash or do you have a stereo system in your car?
What do the needles do specifically?
Old Feb 3, 2004 | 03:11 PM
Default Re: 93 ex electrical problem (riceburner247)
yeah, i was under the dash 2 weeks ago hooking up the switch for my NOS, but it was cool for 2weeks. I have a system also but I've had it for over 2 years, and no problems. I was think it was from the rain yesterday.... not sure
The needles jump around or just go to the bottom. and its only the stuff with lights, the motor run and idles fine.
Old Feb 3, 2004 | 06:02 PM
I would go through and check your connections for the nos. Some of them might have come loose and water could be getting in somewhere.
Did you put a ground anywhere wierd or did you splice into anything under the dash?
Old Feb 3, 2004 | 08:12 PM
accord91lx's Avatar
the only time i've expirened any problems like you describe on y 91 lx...was when the battery was almost completely dead, and the alternator wasnt charging (pully slipping)... they'd jump or bounce or just flat out drop to zero...
Old Feb 4, 2004 | 01:19 AM
Default Re: 93 ex electrical problem (desolate)
Sounds like that is a good explanation too. Might wanna check that out before you go ripping your under-dash apart.
Don Jefe
Oct 27, 2008 09:37 AM
RCurioso88
Jun 28, 2008 10:03 PM
verycleanhatch
May 30, 2006 01:49 PM
felino
Sep 4, 2005 08:08 PM
DA-MAX
Jul 28, 2005 10:55 AM
