Break Lights wont turn on.... Which Fuse?? need help asap
My break lights aren't working at all, and i replaced the bulbs. I'm thinking that its one of two things, either its the switch on the brake pedal, or its a fuse. Now the only fuse that i think it is (which is in my manual) looks like is connected to the horn, is this true? or its the Green Fuse under the hood.. (main fuse box?) By the way i took out the fuse for my horn, cause i need to replace the pin behind the steering wheel.
Anyone know?... it's amazingly great not having break lights...
thanks..
did a search
thanks..
did a search
****, it figures... my horn was on the fritz because the ground pin behind the steering wheel is shot.. and i tried to fix it by cutting it and jimmy rigging it, but unfortunately it didn't work, so i just took the 15w fuse out... Guess i'll have to fix that before i put it back it. Its not fun driving with your horn blaring ^_^ .... its strange that they are both on the same fuse.......
thanks.... much appreciated
Since i know now that the Horn fuse is the same as the break light fuse, i'm ordering the thin metal pin thing behind the steering wheel that keeps the horn constant....
so i can put the fuse back in w/out the horn going crazy..
does anyone know the name of this part?
its a thing .. gold piece of metal that contacts the back of the wheel... keeps the horn constant..???????????
http://www.hondaautomotivepart...SI%29
see if that link works, i'm looking at a part called *PLATE, CONTACT * dont know if thats the part
did a search
so i can put the fuse back in w/out the horn going crazy..does anyone know the name of this part?
did a search
ALLMOTOR EK
Dec 14, 2007 02:05 PM
GreenD16Y8
Aug 8, 2005 03:59 PM
Rhythm Racer
11
Jun 27, 2003 10:46 AM
