CEL #6 an #20 on p13 ECU question
Old Feb 3, 2004 | 03:20 AM
afterburners's Avatar
Default CEL #6 an #20 on p13 ECU question
I have a cel 6 for coolant temp sensor and 20 for Electronic Load Detector. This is for my P13 Ecu for my h22a JDM. My car will not fire up.. it'll turn over for maybe 1 second and then die out. Can these sensors stop you car from starting?
Old Feb 3, 2004 | 06:11 PM
jdm22vtec's Avatar
Default Re: CEL #6 an #20 on p13 ECU question (afterburners)
i got a code 20 once and my car wouldnt start. turned out to be the harness ground. it wasnt bolted down all the way. gave it a couple of cranks down and then the car started fine after that. dont know if that helps.
also an ect code should not prevent your car from starting.
check your grounds.
Charlie Moua
Sep 29, 2014 04:37 AM
pedroa06
Feb 9, 2010 02:42 PM
TurboBA8
Feb 20, 2007 07:25 AM
loid
Sep 15, 2005 03:01 PM
liquidxEG
Feb 22, 2005 03:46 PM
