96 itr ecu
Old Feb 2, 2004 | 09:25 PM
chafik11's Avatar
Default 96 itr ecu
I just bought an 96 p73 ecu(JDM), I used it in my 99 gsr, the car run fast but the VTEC didn't open. I asked the guy who sold it to me and said JDM p73 dont have a pressure switch. I dont know what it is and dont know why?? anyone with an answer?? is it possble be fix??
Old Feb 2, 2004 | 09:33 PM
Kataku2K3's Avatar
Default Re: 96 itr ecu (chafik11)
I know what you're saying about the difference in power between your stock ECU and the JDM P73, it's amazing huh... I personally think the P72 was the worst ECU ever made but then again that's just me (VTEC is too low and the mapping is shitty)... As for VTEC not crossing over, that's really strange... Yes the JDM P73 doesn't look for a VTM (VTEC oil press) signal but that's just one less reason why it wouldn't kick... If this were me I would probably tap a voltmeter off pin A8 (VTS output) on your ECU and see if there's 12VDC+ at ~5700rpm and up... Any CEL? The problem either lies in the wiring of the actual ECU is bad... With your P72 ECU VTEC works fine? Like I said, test the VTS output and see if you get anything... There's no reason why it shouldn't work just fine... Good Luck and let me know if you come up with anything... Peace
Old Feb 5, 2004 | 08:37 AM
chafik11's Avatar
Default Re: 96 itr ecu (Kataku2K3)
thanks for replying to this add. yes, the jdm ecu pull very hard but just that sound of the valves when the vtec quicks i dont hear it. as far as trying to fix it i'm not good in fixiong electronics. what i'm going to do is try it in another car, see if it works if not i'll give it to someone to fix it for me.i'll let you know. thanks again
Old Feb 5, 2004 | 01:08 PM
Katman's Avatar
ok, so you're using a 96 (OBD2a) ECU in your 99 GSR (OBD2b), those are two different types of OBD2 systems going on there.
Am I correct in assuming you're using an ecu jumper harness that allows you to adapt the 96 ecu to your 99 GSR ?
if not, did you rewire your car to use a "D" ecu plug ?
Old Feb 5, 2004 | 07:30 PM
chafik11's Avatar
Default Re: 96 itr ecu (Katman)
the 96,98, 99 it will fit any 94-01 integra, but 200-01 are different, so the jdm 96 ecy(p73) was just plug and play. my car gain enormous power it's just dont open the vtec. the person who sold it to me said the JDM ones dont have the pressure switch, which i dont what it means.so at this point just want to get a rid of it.
Old Feb 5, 2004 | 08:08 PM
Kataku2K3's Avatar
Katman, '96-98 Civics are OBDIIa as we know... '96-99 Teg are also all OBDIIa... Tegs went a year longer...
Modified by Kataku2K3 at 10:51 AM 2/6/2004
Old Feb 6, 2004 | 05:23 AM
irev210's Avatar
haha are u sure that its your AIB's that arnt opening?
ITR ecu doesnt look for AIB's
You need to leave them open or have them run off vac.
Old Feb 6, 2004 | 09:57 AM
Kataku2K3's Avatar
Default Re: 96 itr ecu (irev210)
Umm irev210, what are you talking about? None of us every said anything about a GSR manifold and secondary butterflies... When you say AIB's, do you mean IAB's? Yea, the P73 ECU doesn't have an IAB output but say chafik11he was still running his stock GSR IN manifold, he could do as you said, remove the IAB solenoids and, run the diaphrams line directly to the vacuum port...
Old Feb 6, 2004 | 11:13 AM
irev210's Avatar
i know, I was just refering to how some people get the IAB's opening and the change in intake noise confused with VTEC kicking in.
All i was sugesting is that since his IAB's wernt opening he didnt hear the noise that they normally make, thus causing him to think vtec isnt ingauging.
air intake butterflys
intake air butterflys
my mistake
Old Feb 6, 2004 | 11:23 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chafik11 &raquo;</TD></TR><TR><TD CLASS="quote">the 96,98, 99 it will fit any 94-01 integra, but 200-01 are different, so the jdm 96 ecy(p73) was just plug and play. my car gain enormous power it's just dont open the vtec. the person who sold it to me said the JDM ones dont have the pressure switch, which i dont what it means.so at this point just want to get a rid of it.</TD></TR></TABLE>
well the 99 OBD2a info is questionable to me. I'll have to check that out for myself , but as far as the JDM P73 ecu goes, it having a disabled VTPS sensor (green plug on VT solenoid) is 100% true. But this should not have any direct effect on your vehicle -- VTEC should be working regardless.
You don't hear vtec crossover in your exhaust system around 5700rpm at all ?
EJ8CIVIC
Aug 18, 2015 01:47 PM
QuebecMC
Apr 10, 2014 09:21 AM
lebrecht22a1
Oct 15, 2006 11:08 AM
D-series ninja
Nov 22, 2004 10:06 AM
hatchizzle
May 30, 2003 12:45 AM
