do i need a relay to make v-tec work
Old Feb 2, 2004 | 09:09 PM
racingant's Avatar
Default do i need a relay to make v-tec work
i was would i don't need a relay to make my v-tec kicik in on my 89 civic si single
v-tec this is how i was told to run
red wire- goes to the battery
black wie- goes to a body ground
white wire- goes to negative side of coil
yellow wire- goes to v-tec solenoid
grey wire- not used
NOw i was also told that the msd is giving an ground and i need a pos and was told to us a relay for that now can some tell what do to do thanks
Old Feb 2, 2004 | 09:14 PM
jdmDXrex's Avatar
Default Re: do i need a relay to make v-tec work (racingant)
if you have a stock motor you dont have vtec....
what motor do you have and the proper ecu should activate vtec
Old Feb 3, 2004 | 01:09 PM
racingant's Avatar
Default Re: do i need a relay to make v-tec work (jdmDXrex)
I have a single v-tec motor and i' using a msd rpm activated switch pn 8950 and need to now how to make the msd kick in the v-tec
Old Feb 3, 2004 | 03:26 PM
jdmDXrex's Avatar
why dont you just use a p28 ecu?
Old Feb 3, 2004 | 04:00 PM
onePOINTsix's Avatar
because OBD1 takes the fun out of it you could use a relay, the selonoid dosent take much power so you really dont need to, but if you have a relay handy go for it
Old Feb 3, 2004 | 04:11 PM
jdmDXrex's Avatar
Default Re: do i need a relay to make v-tec work (Sideout)
p28 will make more power.... its got better timing and fuel maps
Old Feb 3, 2004 | 06:05 PM
zCivic's Avatar
well if he is using the MSD RPM switch he is going to need a 30amp relay. The MSD switch has a negitive trigger, so the relay has the 12 volts and when the MSD activates it triggers the ground and v-tec will engage because its a complete circuit. Willing to bet cash is the major draw right now. I drove for a year on a Z6 with a PG7, never had any problems from it how much strong h/p wise I heard seat of the pants only, never seen any graphs, so that may be true but how much never seen/heard. Here is a link to help with the relay wiring http://www.geocities.com/motor....html
Old Feb 3, 2004 | 08:29 PM
racingant's Avatar
Default Re: do i need a relay to make v-tec work (zCivic)
i'll try it
TheEvilBain_TDB
28
Jun 30, 2009 05:56 AM
spettinger
Nov 18, 2004 01:45 PM
davken1102
Aug 2, 2003 06:01 PM
schwett
Jun 2, 2002 12:34 AM
Accord15
Jan 11, 2002 03:28 AM
