axles help
Old Feb 2, 2004 | 08:34 PM
foursquarepunk04's Avatar
Default axles help
hey i have a 1993 integra. and i need to replace the axles. my question is can i use axles from any integra or does it have to be from the same year and engine?
Old Feb 2, 2004 | 09:34 PM
Whitfield Inc.'s Avatar
Default Re: axles help (foursquarepunk04)
90-93 axles and halfshaft are the same - if you use say 94 and up axle / halfshaft you will have to change the axle seals in the trans
Good luck
Old Feb 2, 2004 | 09:38 PM
92b16vx's Avatar
Default Re: axles help (RageDzine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RageDzine &raquo;</TD></TR><TR><TD CLASS="quote">90-93 axles and halfshaft are the same - if you use say 94 and up axle / halfshaft you will have to change the axle seals in the trans
Good luck</TD></TR></TABLE>
Pre 93 teg axles also use a female halfshaft, where as 94+ use a male halfshaft, so you have to use th right combo.
Old Feb 3, 2004 | 08:42 PM
thanks for the help
EF-ingB16
Jan 8, 2011 04:22 PM
4gencivicef9
Feb 20, 2007 09:27 PM
VRD^suzie
Jul 25, 2006 09:23 PM
anotheredhatch
Aug 19, 2004 06:11 AM
JJ-Built
Jan 2, 2002 08:27 AM
