Clearance issues?
Old Feb 2, 2004 | 08:25 PM
C8V6C's Avatar
Default Clearance issues?
I was thinkin about Skunk 2 stage 2 cams for my B16A
It is a stock engine right now, but I want to run a fully built ls vtec later
But my question is should I bother getting the cams right now, or will the power increase not be worth it in a stock B16A? Or am I gonna have to worry about the chance of having clearance issues?
Some people say that it being fully streetable might be a prob too. Is that just due to poor tuning? Cuz this is a daily driver
Thanks, search didn't remedy me
Old Feb 2, 2004 | 09:43 PM
C8V6C's Avatar
Default Re: Clearance issues? (C8V6C)
Anybody?
Old Feb 2, 2004 | 10:10 PM
MEANB18's Avatar
spend your money first on getting the LS/Vtec built. Then worry about cams later. Just my opinion, but you'll like the torque increase with a 1.8L block.
Old Feb 3, 2004 | 03:01 PM
C8V6C's Avatar
Default Re: Clearance issues? (MEANB18)
Makes sense, but I was just hopin for somethin to hold me until I could pull the money together for the block
Old Feb 3, 2004 | 03:15 PM
roadawg's Avatar
You will see good HP gains with the skunk 2 cams in your b16.
Build up the head now so when you are getting parts for your LS/VTEC the head is done.
I am doing the same thing with my b16, the head is being built so I can have fun with the car now and in a year or so I can build a bullet proof bottom end.
Old Feb 3, 2004 | 06:36 PM
C8V6C's Avatar
Default Re: Clearance issues? (hybrid honda)
How about the stage 2s? I heard they might not be comfterblly streeted, or might have a bad idle
So what is all needed for the skunk 2 stage 2s? The cams, springs, retainers, and is that it?
I want to p&p later, but it might be after the ls vtec
Old Feb 4, 2004 | 04:44 PM
C8V6C's Avatar
And what are the differences between the springs/retainers like ctrs, itrs, and the skunk2s?
Old Feb 6, 2004 | 12:00 AM
C8V6C's Avatar
bump
Old Feb 7, 2004 | 07:05 PM
C8V6C's Avatar
Old Feb 8, 2004 | 03:45 PM
jdm_redneck's Avatar
I currently am building this setup for the street, later on when i get enough money i'll build up the bottom end. It is a b16a2, with pretty much every bolt on, my head is getting p&p as we speak, flat .5over nitride coated valves on intake, stock size exhasut valves, ported manifold/bored and tapered throttle body, rocket motorsports valve springs and retainers, and crane cams stage 3 cams, and spoon head gasket. It's gonna suck for now due to only having about a 10.7-11-1 cr.
Old Feb 8, 2004 | 07:33 PM
C8V6C's Avatar
Default Re: Clearance issues? (12000rpm)
Stage 3 isn't too much for daily driving?
VTECROAR96typeR
Dec 28, 2008 06:01 AM
importcrazee2
Mar 14, 2005 07:56 AM
aut0tek
Jul 28, 2004 08:36 AM
keebler65
Feb 6, 2004 02:26 PM
pHizerDC4
May 23, 2003 01:10 PM
