nitrous
Old Feb 2, 2004 | 07:29 PM
DOHC VTEC EG's Avatar
Default nitrous
is it really true if you take a dry kit and get a fuel sylenoid and run 2 hoses to the intake it will be equivelant to a wet kit????
Old Feb 2, 2004 | 08:23 PM
Kendall's Avatar
Basically yes, but you may want to run both the fuel solenoid and the existing nitrous solenoid to the same switch for the sake of simplicity. also make sure that the amount of fuel you'll be injecting is appropriate for the amount of nitrous you'll be injecting.
Old Feb 3, 2004 | 03:13 PM
where can i find out the proper ammount of fuel at for a 55 shot??
Old Feb 3, 2004 | 05:17 PM
Sliced Beard's Avatar
Default Re: (DOHC VTEC EG)
just contact a nitrous company and they should be able to tell you anything you need to know
(techs are usually very helpful at most companies)
Old Feb 3, 2004 | 05:19 PM
Kendall's Avatar
Or you can just buy my wet kit for $200.
Old Feb 4, 2004 | 06:45 PM
Default Re: (Kendall)
what kind is it what shots do you have.where do you live???
Old Feb 4, 2004 | 08:10 PM
boostn420's Avatar
Default Re: nitrous (DOHC VTEC EG)
Well, you would use only one of the 2 solenoids with the dry and eliminate the vacuum part too. You would also need a single fogger jet, the one that has both fuel and NOS fittings.
Old Feb 5, 2004 | 05:33 PM
kendall i cant pm you i dont know why
invisible
Sep 11, 2007 03:53 AM
ephatchsi
11
Jun 10, 2005 11:08 PM
JDM_Risa
Jan 8, 2004 08:27 PM
SilverEP3
Feb 23, 2003 08:34 AM
RICE POLICE SIP
Jan 19, 2003 10:16 AM
