bulb socket for hids mcculloch?
i just got a set of mcculloch hids and it come with the bulb socket adapters 3 prongs for the h4 socket to plug into...
problem is there is no info on which s/be positive and which is negative..and i have only 2 wires from the igniter to plug into...a white and black wire..
i am thinking the white is positive and blacks is ground...but the h4 is 3 prong, so which wire should go on which prong???
pls help...
pls help...
use an ammeter and check which prong does what. if i recall correctly, looking into the plug of the stock H4 plug, the right is ground, the top is low beam, and the left is high beam. double check though.
well for half the price im looking for something a bit brighter then what i have now cause what i have now is ok but i would like better. But the quality is it good on the kit???
wutiteez
21
Nov 9, 2008 09:08 PM
bright white and wider beam
