exhaust gaskets
Old Feb 2, 2004 | 06:24 PM
EM1Guru's Avatar
Default exhaust gaskets
well, as some of you read, i was going to buy a used comptech exhaust. i purchased it, now theres a nice leak where the axle back part connects, and the exhaust vibrates enough to rub on the heat shields. shitty.
so im thinking of starting over. replacing every gasket. from the header to the exhaust. my header also had a leak, but wasnt as bad.
now, onto my questions.
1. is there a O ring gasket in between the cat. conv. and the b-pipe? reason why i ask, there was no O ring gasket when i took off my Racing medallion, and on the ek helms manual it says that there is one.
2. im assuming there are gaskets that are made out of different materials. any kind i should look into?
3. the collector o ring and the axle back o ring are different sizes? the axle back is more expensive then the header collector o ring.
thanks
-julio r.
Old Feb 2, 2004 | 10:27 PM
EM1Guru's Avatar
Default Re: exhaust gaskets (EM1Guru)
Old Feb 3, 2004 | 05:55 AM
EM1Guru's Avatar
noone knows, nobody cares.
RestoRoc89
Jan 28, 2018 09:48 AM
Scott Little
Apr 25, 2016 06:45 AM
jfarrar23
May 25, 2009 09:41 AM
06dx-gblack
Honda Civic (2006 - 2015)
Apr 23, 2008 12:30 PM
YoungKadafi
Mar 12, 2007 12:08 PM
