exhaust gaskets
exhaust gaskets
well, as some of you read, i was going to buy a used comptech exhaust. i purchased it, now theres a nice leak where the axle back part connects, and the exhaust vibrates enough to rub on the heat shields. shitty.
so im thinking of starting over. replacing every gasket. from the header to the exhaust. my header also had a leak, but wasnt as bad.
now, onto my questions.
1. is there a O ring gasket in between the cat. conv. and the b-pipe? reason why i ask, there was no O ring gasket when i took off my Racing medallion, and on the ek helms manual it says that there is one.
2. im assuming there are gaskets that are made out of different materials. any kind i should look into?
3. the collector o ring and the axle back o ring are different sizes? the axle back is more expensive then the header collector o ring.
thanks
-julio r.
thanks
-julio r.
RestoRoc89
01-28-2018 09:48 AM
YoungKadafi
03-12-2007 12:08 PM
