how do u change a clutch master cylinder?
Old Feb 2, 2004 | 06:23 PM
revhigh89's Avatar
Default how do u change a clutch master cylinder?
how do u change a clutch master cylinder? i searched, i cant find anything, thanks guys, ure the best!
Old Feb 2, 2004 | 08:38 PM
JLange's Avatar
Default Re: how do u change a clutch master cylinder? (evilryu530)
its not that hard, get a helms or something of the sort to start out, cause you will need one in future. basically just go through and use your eyes and see what you need to remove, i think its a couple lines and something attached to clutch pedal. youll need some brake fluid to refill it up and bleed out all the air, that takes 2 people unless you have speed bleeders
Old Feb 3, 2004 | 07:18 AM
ebelp's Avatar
Default Re: how do u change a clutch master cylinder? (jtintegra)
Basically, just pinch of the main fluid line going to the MC, remove the hose clamp on that line, then everything else just unbolts. A couple bolts on the MC, and a couple bolts behind the clutch pedal. It's very easy. Don't forget to replace the slave cylinder too.
Old Feb 15, 2004 | 03:10 PM
crawdad689's Avatar
Default Re: how do u change a clutch master cylinder? (ebelp)
........and is it very similar to replace the slave, (except for the fact that it's on the outside of the car)?
just 1 line and a couple bolts?
bigsnorlax
Feb 21, 2020 10:40 AM
R81_DC2
Aug 14, 2009 08:54 PM
prjctsilverknighty2k
Transmission & Drivetrain
Jun 8, 2009 10:47 AM
92eg6lsvtec
May 20, 2006 05:56 AM
TeginRAGE
May 1, 2002 05:30 AM
