what the hell!
ok i just got the new motor in my crv.
but i have one problem that is driving me nuts
i have a crackshaft speed sensor CEL.
and sometimes when i just crack the throttle a little it blips up and down.then when you give it more gas it stops. also it will not idle up when cold it still idle low. like almost wants to die. some times it does. but once it warms up it idles fine.
here is the setup.
lsvtec
b18a block
gsr pistons
milled .030 b16head with 95 gsr cams, valve lash .006 in/.007 ex
99 si intake manifold with itr T/B
00' si ecu
any ideas? could the ckf sensor be causing this
here is the setup.
lsvtec
b18a block
gsr pistons
00' si ecu
Sewer Rat
Acura TL, RL & ZDX
Mar 27, 2006 10:56 AM
