Buying Work Emotion CR wheels, final questions....
Old Feb 2, 2004 | 04:30 PM
Shawn's Avatar
Default Buying Work Emotion CR wheels, final questions....
I am going with some gunmetal Work Emotion CR wheels 17 by 8. I noticed a couple offsets, which one is recommended? 42? 47? Also they are gonna be wrapped in Bridgestone Potenza S-03's, what tire size would be recommended for the wheels? Thank you for any help, it's greatly appreciated ! -Shawn
Old Feb 2, 2004 | 04:47 PM
GreenBean's Avatar
Default Re: Buying Work Emotion CR wheels, final questions.... (Shawn)
The tires should be 225/45/R17
As for the offset, you can go either way...
Check this out and see for yourself http://toy4two.home.mindspring.com/offset.html
The 42mm will stick out 22mm and the 47mm offset will stick out 17mm,
Old Feb 2, 2004 | 04:53 PM
Stellar1's Avatar
Default Re: Buying Work Emotion CR wheels, final questions.... (GreenBean)
Such a wealth of Information in the RSX forum you are GreenBean.
Old Feb 2, 2004 | 06:18 PM
RsxVengeance's Avatar
you should get the 42 mm offset with a 17x8 rim.
Old Feb 2, 2004 | 09:43 PM
DC5RK20A's Avatar
Default Re: (RsxVengeance)
Also you can run a 215/45/17 on it, and that is really the recommended size. The stock offset is what 45? If so, going with a wider wheel you want a lower offset number.
Chris
Old Feb 3, 2004 | 02:32 AM
GreenBean's Avatar
Default Re: (DC5RK20A)
I was getting the 225 width from the guys at http://www.tirerack.com....
If the wheel is 7.5-8.0"wide they recommend the 225, if its only 7.0" wide they recommend the 215.
Old Feb 3, 2004 | 09:59 AM
that guy steveee's Avatar
Default Re: (GreenBean)
umm, whats an easy way to explain offset? Is it from the center to the outside lip?
Old Feb 4, 2004 | 04:49 AM
Mi4dc5's Avatar
Default Re: (simann)
I THINK the offset is the length between one stud and the other stud going across from each other?
Old Feb 4, 2004 | 08:11 AM
Shawn's Avatar
inlinefour.com is where I think I am going to order from, but the only offer the 17 by 8 wheels with a 47 offset. Is a 42 offset worth looking at other sites? Thanks for the help guys. -Shawn
Old Feb 4, 2004 | 06:51 PM
Reborn's Avatar
Reborn_
i just recently bought these wheels in 17x7 +47 offset. i bought them used. i wanted to get 17x7.5 +42.i was concerned that with a +47 offset, it would look like it stuck in too much, but it looks great. howeever, if i was u, id try my best to get the +42 since u are running 17x8. i dont think its critical though
Old Feb 5, 2004 | 10:57 PM
Shawn's Avatar
Default Re: (Reborn)
Does anyone know where I can find a set of 17 by 8 gunmetal wheels with a 42 offset?? All help is appreciated. -Shawn
Old Feb 6, 2004 | 02:22 AM
^jefs0ng's Avatar
Banned
Default Re: (Shawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shawn &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know where I can find a set of 17 by 8 gunmetal wheels with a 42 offset?? All help is appreciated. -Shawn</TD></TR></TABLE>
Possibly EVASIVE
Old Feb 6, 2004 | 10:04 AM
Shawn's Avatar
Default Re: (#jefs0ng)
Ok. From what I have seen online my options are 17 by 7 with a 42 or 47 offset, or 17 by 8 with a 47 offset only. I guess what I am asking is, what would you pick? If anyone could explain the benefits and cons of each size I would really appreciate it. -Shawn
Old Feb 8, 2004 | 04:10 PM
Shawn's Avatar
Default Re: (Shawn)
Still wondering if I can find a 17 by 8 wheel with a 42 offset. I am pretty sure they aren't made in a 42. Should I go for 17 by 7 so I can get a 42 offset, or just stick with wider wheel with a 47 offset. I appreciate all the help. -Shawn
Old Feb 9, 2004 | 01:30 PM
cjump85's Avatar
Default Re: (Shawn)
post some pics soon.... i want those wheels as well but in 16's. i am just curious to how they will look... keep us updated
DC5mike
Jun 12, 2008 06:39 AM
OneSickJDMBB6
Apr 5, 2007 05:07 PM
breathinez
Oct 20, 2006 03:29 PM
FrostyDC4
Mar 29, 2005 10:01 PM
Teh_Oven
Jan 31, 2005 10:13 PM
