Honda S2000 Honda S2000
STEREO
Old Feb 2, 2004 | 02:22 PM
pearlws's Avatar
Default STEREO
i installed some mods on my car and i unhooked my negitive battery and hooked it back on. and then my stereo doesnt work till i type in the radio code. and the honda dealer said they need to take my stereo out to get the serial number. and there asking $100 to do that. is there any other way i can get the radio code. are all the s2000 radio codes the same? and how do i take out my sterio. thanks
Old Feb 2, 2004 | 02:25 PM
munckee's Avatar
Default Re: STEREO (pearlws)
The code may be on a sticker on your head unit. Its very easy to remove.
Open the radio door and pull gently but firmly until you remove the door and the frame around it (ie the part with the vents, etc that holds the radio door in). There are four screws behind it that hold the headunit it.
DON'T pay the stealer $100 to do that for you!
Old Feb 2, 2004 | 02:33 PM
pearlws's Avatar
Default Re: STEREO (munckee)
thanks man. will all the s2k radio code work on all the s2ks?
Old Feb 2, 2004 | 02:40 PM
dkim48's Avatar
if you just bought a 04' you should have the radio code card in your owner's manual booklet.
Old Feb 4, 2004 | 08:13 PM
pearlws's Avatar
Default Re: STEREO (dkim48)
its not in there i checked and so did the HONDA dealer.
Old Feb 6, 2004 | 01:32 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearlws &raquo;</TD></TR><TR><TD CLASS="quote">thanks man. will all the s2k radio code work on all the s2ks?
</TD></TR></TABLE>no, your radio has it's own code.
Old Feb 7, 2004 | 07:31 PM
ak-s2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearlws &raquo;</TD></TR><TR><TD CLASS="quote">its not in there i checked and so did the HONDA dealer.</TD></TR></TABLE>
If you have an 04 and they did not give you the radio code then you should not have to pay them to find the code.
Old Feb 9, 2004 | 02:31 AM
M-Type's Avatar
Default Re: STEREO (ak-s2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ak-s2000 &raquo;</TD></TR><TR><TD CLASS="quote">
If you have an 04 and they did not give you the radio code then you should not have to pay them to find the code.</TD></TR></TABLE>
seriously, if you just bought the car and they forgot to give you a code, you shoulnt pay 100$.
Old Feb 9, 2004 | 04:55 AM
gradualepiphany's Avatar
Default Re: STEREO (M-Type)
$100 to pull the radio out and find the code? That's preposterous. If I'm not mistaken, they should be able to run your VIN number and just look it up...
|andrew|
Old Feb 9, 2004 | 09:48 AM
dkim48's Avatar
Default Re: STEREO (gradualepiphany)
something does not sound right...you bought a brand new 04' s2k and you didnt get the radio code card with the car when purchased? please tell me the dealer you bought yours at so i never go there...but then again this has to be bs...how would you not get the code?
Old Feb 10, 2004 | 12:01 PM
lonnieboost's Avatar
Open up the little compartment in the middle, there will be 5 numbers on a white sticker that is your code
Old Feb 10, 2004 | 10:41 PM
Sukebei Oni's Avatar
Default Re: STEREO (lonnieboost)
can't the dealer get the code from your vin number?
acuradrivr
Audio / Security / Video
Sep 20, 2004 01:54 PM
Ricey McRicerton
Sep 8, 2003 06:14 AM
