DA trailing arm bushings
Honda doesn't make a replacement bushing for the rear trailing arms(at least not for the DA). There is a pretty informative thread about replacing it here: http://www.g2ic.com/forums/sho...shing
Interesting read, thanks
So the consensus to date is that there is no replacement save the custom Mugen bushings, and no one is sure if the EF trailing arm will bolt to the DA rear brakes.
My rear trailing arm bushings are torn enough that during hard cornering I hear a thud-thud-thud noise, presumably caused by the arm hitting the body of the car
So the consensus to date is that there is no replacement save the custom Mugen bushings, and no one is sure if the EF trailing arm will bolt to the DA rear brakes. My rear trailing arm bushings are torn enough that during hard cornering I hear a thud-thud-thud noise, presumably caused by the arm hitting the body of the car
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nino »</TD></TR><TR><TD CLASS="quote">Honda doesn't make a replacement bushing for the rear trailing arms(at least not for the DA). There is a pretty informative thread about replacing it here: http://www.g2ic.com/forums/sho...shing</TD></TR></TABLE>
Trial users go home!
What's this guy doing here!?!?!??!
At the price of either new arms or inserts, I make one of two choices: Fill the bushings w/ window-weld or put up with the crappy bushings
I don't drive a CRX 'cause I'm in the money.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports »</TD></TR><TR><TD CLASS="quote">or look for a set of dc t.a. people replace theirs with itr ta so you might find a set that way. then you can use the mugen ones.</TD></TR></TABLE>
Exactamundo! But he's got limited funds. How much are you guys selling TA's for ? If the price is right I will take a set
Schu
Schu
Reelizmpro
Feb 27, 2006 01:31 PM
