TPS
Old Feb 2, 2004 | 09:49 AM
Combustion Contraption's Avatar
Default TPS
im throwing a tps code on my ls/vtec swap when i use a pr4 ecu (forced to cuz the ecu i was planning on using is junk) and it idles around 1500. I searched and read a few posts about calibrating the tps and my question is, if the voltage is off, does it throw a code? With my junk ecu (p08) the motor idles fine. ( the reason the p08 is junk is cuz you cant pull codes from it and its forever stuck in limp mode.) Thanks in advance for the help.
Old Feb 2, 2004 | 10:24 AM
***bump***
Old Feb 2, 2004 | 05:00 PM
Old Feb 3, 2004 | 02:18 PM
please. i have to fix this tonight..
EKIM NART
Feb 22, 2006 06:56 AM
-KangaRod-
Jun 22, 2005 05:45 AM
imlachg1
16
May 22, 2004 06:04 PM
See Are X
Aug 19, 2002 03:07 PM
