how hard is it to change valves
Old Oct 5, 2001 | 03:49 PM
95gsr's Avatar
Default how hard is it to change valves
ok i have the head off I need to know how hard is it to take the valves off and put new ones in also doing springs and retainers thanks
Old Oct 6, 2001 | 03:21 PM
95gsr's Avatar
Default Re: how hard is it to change valves (95gsr)
anyone
Old Oct 6, 2001 | 04:35 PM
Big Teggie's Avatar
I would also like to know, when i get valve i would liek ot save money and do it myself if i can. I know someone out there knows how to do it and give us some pointers or info.
Old Oct 7, 2001 | 03:02 PM
GTEater's Avatar
my friend Calvin(TypeC) took an entire day swapping out the valves and valve springs......its a pain in the *** cuz you need a special tool to compress and set the valve spring into the head......the one for your specific model will cost about 100 bucks......Calvin got a universal one from autozone for really cheap, but since the head symmetrics differ for every cylinder, he had to bend it and modify it for every set of springs he did.....the easiest thing i think would be to remove everything from the head and then pay a shop to install the valves, springs, and retainers into the bare head......the labor for this will cost about as much as the valve spring tool you need....i don't think you need the tool to remove the valvetrain......contact typeC at mstrmind97@aol.com.........he should net you know all the details on the install
Old Oct 7, 2001 | 03:10 PM
VTECAcuraGSR's Avatar
Default Re: how hard is it to change valves (GTEater)
Getting the retainers and valves out are not the problem. You need the tool to install the valve retainers. You might want to check how much it cost at a local shop. It may be worth it
Old Oct 7, 2001 | 04:38 PM
C-speed's Avatar
Default Re: how hard is it to change valves (VTECAcuraGSR)
Check here for some info and pics:
http://www.c-speedracing.com/howto/nabuild/nabuild.html
HTH
Old Oct 7, 2001 | 08:07 PM
Mr. Softee's Avatar
Default Re: how hard is it to change valves (G3-TEG)
usually you dont want to do valves without a valve job... which a machine shop shoudl do.
f22beast
Jan 17, 2010 10:02 AM
B18T3T4
Dec 9, 2006 06:29 PM
herde1724
Jan 27, 2005 11:41 PM
ITRfaithful
Feb 19, 2003 04:05 PM
TheLostOne
Dec 11, 2001 05:40 PM
