hondata experts p72 question
i need to get a hondata for my all motor h23, i want to run and p72 so i can still try and use my knock and egr making the p72 my only choice. My question is, and i did search, does it have to be an obd1 p72, or are they basically the same once hondata chips them and you burn a program onto them?
I am a Hondata dealer and i do recommend going with the p75 ecu. When using the p72 you can just tune the low map and make it work for your application but you will not beable to make the egr work because the ecu doesn/t read it. As far as the knock sensor is concerned if your car is tuned properly and the air/fuel ratios are good you really won't need the knock sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prospeed »</TD></TR><TR><TD CLASS="quote">I am a Hondata dealer and i do recommend going with the p75 ecu. When using the p72 you can just tune the low map and make it work for your application but you will not beable to make the egr work because the ecu doesn/t read it. As far as the knock sensor is concerned if your car is tuned properly and the air/fuel ratios are good you really won't need the knock sensor. </TD></TR></TABLE>
Exactly what I was thinking. Good post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeTuner »</TD></TR><TR><TD CLASS="quote">If it doesnt read the egr then does that mean that it wont throw egr related codes?</TD></TR></TABLE>
Yeah I was running a P72 I just blocked my EGR with the Hondata gasket..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ludeSi »</TD></TR><TR><TD CLASS="quote">interesting, i know i can get a p28 cheap, or should i look for a p74/75??</TD></TR></TABLE>
http://cgi.ebay.com/ebaymotors...29350
