***Hondata eprom burners so on so forth***
Old Feb 1, 2004 | 07:35 PM
2k1_ITR_0736's Avatar
Default ***Hondata eprom burners so on so forth***
Anyone have any idea on what exactly is needed, im under the impression that i can have any programmer, as long as i use a compatible chip with the programmer.. what voltage are the chips in the ecu? i noticed most sensors and junk that come out of the ecu are up to 5v, but does anyone know exactly what chip voltage is needed? also, anyone have these items, that they like and are easy to use? reccommendations?
Old Feb 2, 2004 | 10:08 AM
tgreaves's Avatar
Default Re: ***Hondata eprom burners so on so forth*** (2k1_ITR_0736)
I have a willem burner that I use for my custom ecu(not hondata).. Go to willem.org and check out the ones that they have.. Its easy to program with them and they are only like $70.00 or so..
Old Feb 2, 2004 | 10:18 AM
fox297's Avatar
You should get the 29C256 chip, it's 5V. It plugs directly to your ecu socket.
Old Feb 2, 2004 | 10:36 AM
tgreaves's Avatar
Default Re: ***Hondata eprom burners so on so forth*** (fox297)
Either 27c256 or 29c256 chips will work.. The 29c256 chip is better because you can electronically erase them and burn to them again.. The 27c's you need a uv light eraser or reburn with them..
Old Feb 2, 2004 | 01:10 PM
MrTodd's Avatar
Default Re: ***Hondata eprom burners so on so forth*** (tgreaves)
Not all 27C's need a UV-light. Head over to Batronix.com and they have a new 27C256 electronically erasable style chip. I just ordered a few of those, so we'll see how it turns out.
Old Feb 2, 2004 | 01:16 PM
tgreaves's Avatar
Default Re: ***Hondata eprom burners so on so forth*** (MrTodd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd &raquo;</TD></TR><TR><TD CLASS="quote">Not all 27C's need a UV-light. Head over to Batronix.com and they have a new 27C256 electronically erasable style chip. I just ordered a few of those, so we'll see how it turns out.</TD></TR></TABLE>
The how does the new 27c's differ from the 29c's..
IntegraPir4te
Jun 19, 2007 01:07 PM
inh
Apr 19, 2006 08:30 AM
D3U1LT
Jun 6, 2005 07:04 PM
iBrandon
Apr 18, 2005 08:01 PM
deeweewoo
Mar 2, 2005 03:53 AM
