Best ECU for ODB0 -> ODB1 conversion
Like it says , what is best ECU to use in an ODB0 to ODB1 converion for run Single O2 sensor. WHat has best fuel maps and is ready to roll. Without expensice custom tuning. This is for a B16A1 with Skunk cams 4-1 JDM header and a larger TB and ITR style intake. Obviously Dizzy will be swapped.
Tried search and read , adn read and read, but question was never answered.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch »</TD></TR><TR><TD CLASS="quote">The only downside is the P28 can not use a knock sensor.</TD></TR></TABLE>
If, of course, you consider this to be a down side at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">
If, of course, you consider this to be a down side at all.</TD></TR></TABLE>
tr00
tr00
Was just reading back through the tread and saw this last answer. The whole point of an ODB1 conversions is I have a JDM 4-1 header I want to run and the PR3 I have now requires 2 O2 sensors, on on Cyl pairs 1+3 and another on 2+4 which is a little hard to do when all 4 dump into one collector. Unless someone has tried O2 sensors on #1 and #4 down tubes which I believe should work. O2 sensor doesn't know if its 1, 2 or 4 cylinders feeding it. But if the computer doesn't see it respond it will run like crap. And Cylinders are controlled in pairs so if one of those pairs is read it should still work. But nobody has tried this yet. That has answered me anyway.
Well I want to keep knock sensor. It does serve a good purpose. Someone told me a P30 is a better choice since it does use knock sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox297 »</TD></TR><TR><TD CLASS="quote">If you don't want any hassle, get the PR3 ecu, it's made for B16.
Modified by fox297 at 7:24 PM 2/2/2004</TD></TR></TABLE>
i think u mean an obd1 P30, not a obd0 Pr3
I hope thats what he means, I already have a PR3 but that and PW0 both use 2 O2 sensors to corol two pairs of cylinders seperately. Hence the 4-1 header problem.
Vladglad
Jun 13, 2017 03:29 PM
ekcivic2
Engine Management and Tuning
Jun 19, 2010 09:59 AM
dkrex001
Oct 1, 2006 10:34 PM
lilxvtecxpwr
Aug 19, 2002 10:18 AM
