Intermediate shaft removal 4th Gen
Old Feb 1, 2004 | 04:54 PM
OTT's Avatar
OTT
Default Intermediate shaft removal 4th Gen
Can anyone plz explain how you remove and replace this please (pics if poss)
I tried searching but doesnt com up with anything (im sure i can remem a thread on it! ?)
Old Feb 1, 2004 | 06:53 PM
99spanishGT
Guest
Posts: n/a
Default Re: Intermediate shaft removal 4th Gen (OTT)
you have to unbolt from block !
Old Feb 2, 2004 | 04:12 AM
PirateMcFred's Avatar
I've never had any issues. Pics should not be necessary it is really straight forward, you unbolt the three bolts on the driver's side and then pull and wiggle and it just slides out. be sure to drain your tranny fluid.
Old Feb 2, 2004 | 01:44 PM
OTT's Avatar
OTT
Thats my passenger side though.
Is it possible to just remove the left drive shaft? and how. I fthe int. shaft needs to be removed also the were are the three bolts (bear in mind Im doing this whenever i get chance do its gonna be this weekend I get to go down but I need to order the part before)
Cheers
Old Feb 3, 2004 | 12:52 AM
OTT's Avatar
OTT
bump ttt
Old Feb 3, 2004 | 07:06 AM
99spanishGT
Guest
Posts: n/a
Default Re: (OTT)
i think you have to pull both but just get under there and fool around, you should see how it goes togeter!
Old Feb 3, 2004 | 08:04 AM
solowerks's Avatar
completely unbolt the driver side axle from the hub. Remove the bolts holding the intermediate shaft to the block. Try pulling the whole axle and intermediate shaft from the tranny. If it doesn't come out try using a little persuasion between the tranny and the intermediate shaft to loosen it but be careful not to hurt anything. I unbolted the lower control arm from the strut because it was easier to pull the axle out for me. Thats about it.
Old Feb 3, 2004 | 11:21 AM
OTT's Avatar
OTT
Wheres the drain plug for the tranny? and does anyone know the capacity?
Old Feb 3, 2004 | 12:20 PM
Default Re: (OTT)
It is Number 10 and it is 2 quarts of fluid
Old Feb 5, 2004 | 07:07 AM
OTT's Avatar
OTT
Cheez dude
Greatness
Jan 15, 2010 05:21 PM
Tommy_Gunns
Apr 13, 2009 09:39 PM
Happy Gilmore
Dec 2, 2008 01:55 PM
Wayne_Curr
Feb 12, 2006 05:41 PM
chickenstrip
Nov 28, 2005 11:53 AM
