spoon calipers
if you want to put the spoon calipers just by itr rotors and take them to a machine shop and get them redrilled to 4x100 because the rotors are wider than the other integra models you can even use prelude rotors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mipawi »</TD></TR><TR><TD CLASS="quote">if you want to put the spoon calipers just by itr rotors and take them to a machine shop and get them redrilled to 4x100 because the rotors are wider than the other integra models you can even use prelude rotors</TD></TR></TABLE>
But will the stock GSR caliper brackets work? Aren't they spaced a little different to compensate for the larger rotor?
spoon offers a big brake kit for the 4 lug models, kinda expensive but you get alot.
around $2500 you get spoon front calipers,rear itr calipers, 4 new rotors,(itr size but with the correct holes,new sets of spoon pads,and all the hardware needed to make it work.
they call it big brake conversion kit for eg6. just ask you nearest spoon dealer.
